'04 question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by R33615, this thread has received 2 replies and been viewed 745 times.
post #1 of 3 (permalink) Old 04-14-2009, 05:16 PM Thread Starter
'04 question
My buddies truck will start for about 3 seconds then die, and then do nothing but crank after it dies. Sometimes he will try it later on and it will will start and stay running. Its also kind of hesitant when he floors it, which could indicate clogged fuel filters... Is there any other common problem that could cause these symptoms?
'03 F250 CCSB SRW, SCT, K&N, MBRP STRAIGHT PIPED, SNOW STG 3, LIFTED 6" ON 37'S, RCD's EGR DELETE, AP HD200, TP STG 1 FUEL SYSTEM, HYPERMAX STG 1 INJECTORS, ARP'S, ID TUNED, VARIOUS LITTLE GOODIES...
R33615 is offline
post #2 of 3 (permalink) Old 04-15-2009, 02:03 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
your probably right on with the fuel filter being clogged, change it and then see what happens afterwards
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 3 (permalink) Old 05-04-2009, 01:15 AM
Sometimes the black Bleeder screw will crack and leak air into the filter and cause it to die. Try pumping the little primer til its rock hard and look for fuel leaks around the filter and by the FICM and the cp3. I had a problem with my supply hoses dry rotting.
nmband13 is offline
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 03:35 PM
Boost question, maybe MAP sensor question 6_Myles 1994-2003 7.3L Power Stroke 5 10-28-2006 12:42 AM
Edge Juice Question Question Jaadc01 General Ford Truck and Excursion 6 05-23-2006 12:40 PM
