2003 White smoke? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by barbershop, this thread has received 2 replies and been viewed 1090 times.
post #1 of 3 (permalink) Old 04-25-2009, 03:13 PM Thread Starter
idunnoyet
barbershop's Avatar
2003 White smoke?
OK my Dads 03 has a haze of white smoke most of the time at an idle and then is pretty thick when whe first throttles it after a long idle. Truck is Stock, about 130,000 miles. Also this doesn't happen all the time and we cant find any fuel in the oil, seems that it only smokes when the temp is running a bit cooler. Is it possible that the thermostat could be the problem or justand injector problem??
Also the fan motor on the A/C sometime runs for up to 30 minutes after the truck has been cut off??? thanks for any help.
2012 Z-71 Duramax
1987 379 Peterbilt 425 Cat, RTX 15715, 390 rear ends.
1994 379 Peterbilt 425 Cat, 9 speed, 3:70 rears
Also drive anything that is overloaded and fast!!
CAN YOU KEEP UP!?!?!?!?
barbershop is offline
post #2 of 3 (permalink) Old 04-26-2009, 08:43 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
white smoke is an injector issue, take it to the stealer, with 130,000 miles it will still have injector warranty
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 3 (permalink) Old 05-05-2009, 02:09 PM Thread Starter
idunnoyet
barbershop's Avatar
took it to the stealership, they said I need to change both thermostats first, that it seems to just be running cool. And also everytime they would plug in their computer my truck would blow their fuse in the computer. I need a wiring diagram on the cig. lighter power source and a sticky on how to change the thermostats. Any help please!
2012 Z-71 Duramax
White smoke blue smoke low on coolant whats wrong littlebigrig6.0 2003-2007 6.0L Power Stroke 24 12-06-2009 12:11 AM
white smoke vs. black smoke DUMPIN99 1994-2003 7.3L Power Stroke 20 03-08-2008 12:01 AM
08 White smoke??? 08stone350 2008-2010 6.4L Power Stroke 5 06-19-2007 04:30 AM
White Smoke Smokin7.3 1994-2003 7.3L Power Stroke 9 11-30-2005 06:07 AM
