Throwin Codes! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fordt, this thread has received 6 replies and been viewed 3598 times.
post #1 of 7 (permalink) Old 07-08-2009, 04:14 PM Thread Starter
Administrator
fordt's Avatar
Images: 5
Throwin Codes!
2001 LB7
155,000 miles
Throwin codes, and seems to be stuck in some sort of limp mode.
P0087
P0463** Fuel Level Sensor Circuit High Input
P1093
P1094
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #2 of 7 (permalink) Old 07-11-2009, 12:20 AM
duramax9878's Avatar
just a thought but it sounds like the fuel rail is losin presure a shim kit should help
Danny
2006 LBZ Chevy with 4in. straight back Duals, K&N Intake, EFI Live V2, PPE Standard, BD Exhaust Manifold, Mickey Tompson Tires and Auto Meter Gauges, Tie Rod Sleeves, Pitman Arm Braces, N Fab Nerf Bars, Recon Smoked Cab Lights, Halo Projector Headlights, and more soon.
duramax9878 is offline
post #3 of 7 (permalink) Old 07-11-2009, 02:33 AM
You sure those codes are correct?
mckey73 is offline
post #4 of 7 (permalink) Old 07-13-2009, 02:12 PM Thread Starter
Administrator
fordt's Avatar
Images: 5
I did no take them out of the truck myself, a friend did. He is supposed to trade a gasser Ford for this truck today, so I will be able to get into the truck later tonight and see for sure.
-Wayne
fordt is offline
post #5 of 7 (permalink) Old 07-13-2009, 07:08 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
Originally Posted by fordt View Post
2001 LB7
155,000 miles
P0087
P1093
P1094
P0087 The Engine Control Module (ECM) monitors Fuel Rail Pressure (FRP) using the fuel rail pressure sensor. If the sensor indicates a pressure less than the commanded rail pressure plus a possible transitional overshoot, the ECM will set Diagnostic Trouble Code (DTC) P0087 for fuel rail pressure too low.
P0463The fuel level sender changes resistance based on fuel level. The PCM monitors the signal circuit of the fuel level sender in order to determine fuel level. When the fuel tank is full, the sender resistance is high and the PCM senses a high signal voltage. When the fuel tank is empty, the sender resistance is low and the PCM senses a low signal voltage. The PCM uses the signal circuit of the fuel level sender in order to calculate the total remaining fuel %) in the tank. The PCM sends the fuel level percent via the class 2 serial data circuit to the instrument cluster in order to control the fuel gauge. The fuel level information is also used for misfire and EVAP diagnostics.
P1093
P1094
2003 F250 "Pulling Truck"
hhrecovery is offline
post #6 of 7 (permalink) Old 07-13-2009, 08:03 PM Thread Starter
Administrator
fordt's Avatar
Images: 5
We just pulled the codes.
P0087
P0463
P0540
P1093
P1094
Truck is sluggish, stomp it to the floor and it has no power, medium black smoke.
-Wayne
fordt is offline
post #7 of 7 (permalink) Old 07-13-2009, 08:09 PM Thread Starter
Administrator
fordt's Avatar
Images: 5
Found out that the truck was acting up, they replaced the fuel filter, the new one was leaking around the top and they drove about 600 miles home that way. Replaced the FPR, which did not help.
-Wayne
fordt is offline
Throwin Codes smokercummins74 5.9L Cummins (2003-2007.5) 2 04-28-2009 01:35 AM
uh oh I'm throwin codes.. GruntTorque 2008-2010 6.4L Engine Tuner Forum 25 04-09-2008 02:27 PM
codes GOAT 5.9L Cummins (2003-2007.5) 4 02-21-2008 05:31 PM
DTC codes Whisperinghorse 1994-2003 7.3L Power Stroke 2 08-16-2007 05:23 PM
throwin codes xjjeep00 5.9L Cummins (1998.5-2002) 5 07-16-2007 04:05 AM
