02 LB7 starts and shuts down - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dmaxlb7, this thread has received 13 replies and been viewed 5431 times.
post #1 of 14 (permalink) Old 07-27-2009, 01:15 AM Thread Starter
I took it to the dealer and they said it was a bad crankshaft position sensor. Replaced that, turns out that's not the problem. I had my friend's computer on it and the only code it threw was an old security code. We cleared it but it didn't help. Anyone have an idea what it could be? Any info would be greatly appreciated.
dmaxlb7 is offline
post #2 of 14 (permalink) Old 07-27-2009, 05:28 PM
Pardue the Traveler
New 0mega's Avatar
Have you checked the fuel filter, is your lift pump not working properly, check the injectors? Thats what I can think of for now.
Singles Club member #250
New 0mega is offline
post #3 of 14 (permalink) Old 07-27-2009, 05:34 PM
is here and there.
Rcannon's Avatar
Images: 11
Filter housing crack? If you recently changed your filter you may have air leak in the system.
Rcannon is offline
post #4 of 14 (permalink) Old 07-28-2009, 03:55 AM Thread Starter
It seems to be an ignition issue. The filter is new. It fires up, runs for a few seconds and shuts down. The rail pressure and all that seems fine.
dmaxlb7 is offline
post #5 of 14 (permalink) Old 07-28-2009, 12:42 PM
is here and there.
Rcannon's Avatar
Images: 11
If it starts, why would you say it's an ignition issue?
You say the filter is new, how new? Has it run since you replaced the filter?
Rcannon is offline
post #6 of 14 (permalink) Old 07-29-2009, 12:15 AM
Gone Fishin...
merlin5577's Avatar
Since the Duramax engines do not have a lift pump, and the engine fires right up, I doubt its a fuel problem. My guess would be the coolant temperature sensor. If the sensor was bad it would do exactly what your describing. Is your check engine light on?
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #7 of 14 (permalink) Old 07-30-2009, 04:53 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
well it cant be an ignition issue because if it runs, then it is igniting the fuel, diesels are a "compression ignition" engine, they create extreme pressures in the cylinders which creates heat and that starts the combustion of the diesel fuel, theres no spark plugs, no coils, no distributor..... im sorry if you knew that, just trying to spread the knowledge of the mighty diesel
I would have to agree with Merlin tho...
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
merlin5577 (07-30-2009)
post #8 of 14 (permalink) Old 07-30-2009, 05:21 AM
Pardue the Traveler
New 0mega's Avatar
Could it be a blown fuse?
post #9 of 14 (permalink) Old 08-06-2009, 11:57 PM
Auto or manual?
mckey73 is offline
post #10 of 14 (permalink) Old 08-18-2009, 09:37 PM
stock is boring
My '04 is doing the exact same thing and blowing a lot of white/gray smoke.
'04 LB7 4DR LONG BED 4x4
'02 LB7 REG CAB Utility body 2wd
dragnsled is offline
shuts off garbageman_7 1994-2003 7.3L Power Stroke 4 07-26-2009 10:28 PM
Truck idles good then just shuts off 7.3stroker281 1994-2003 7.3L Power Stroke 8 01-31-2008 01:54 PM
6.5 Shuts off by itself Ronzoni007 6.5L Diesel Engine 15 08-14-2007 01:27 PM
6.5 diesel shuts off driving:( Liftedpsd 6.5L Diesel Engine 1 05-31-2007 01:54 PM
99 7.3 shuts down in the rain thw1 1994-2003 7.3L Power Stroke 4 01-08-2007 08:09 PM
