E 04 stalling out? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by camojeeper, this thread has received 12 replies and been viewed 1628 times.
post #1 of 13 (permalink) Old 07-31-2009, 01:27 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
E 04 stalling out?
hey guys i got a buddy with an early 04 dmax and it will stall out sometime comming back to idle Im going to see him and run AutoE on it but it isnt seetting any codes. Im not much of a dmax guy can you point me in the right direction?
thanks
steve
STEVE TDG MAFIA#106
camojeeper is offline
post #2 of 13 (permalink) Old 07-31-2009, 01:30 AM
Gone Fishin...
merlin5577's Avatar
When you say; "stall out sometime comming back to idle" do you mean it was at full throttle and when it was taken off full throttle it is stalling?
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #3 of 13 (permalink) Old 07-31-2009, 02:38 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
sorry no like coming to a stop as the tranny comes out of lock up and returns to idle it will stall but not all of the time happened 2 times in 500 miles
STEVE TDG MAFIA#106
post #4 of 13 (permalink) Old 07-31-2009, 07:16 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
this is what ive got so far OBD-II Diagnostic Trouble Code Report
Shop: Magic Smoke Performance
Address: 1360 third st red bluff ca
Phone: 530-526-6262 Fax:
Email: magicsmokeperformance.com
Timestamp: 7/31/2009 10:05:45
Make: Chevrolet Model: Duramax Year: 2004
VIN:
MIL: On
Diagnostic Trouble Codes
Generic Powertrain
P0087 Fuel Rail / System Pressure - Too Low
P0380 Glow Plug/Heater Circuit A
P1093 Fuel Rail Pressure Low During Power Enrichment
Freeze Frame (Frame 0)
Calculated Load 25 % Calculated Load 25 %
Coolant Temperature 145 F Coolant Temperature 145 F
Intake Manifold Absolute Pressure 27.4 in.hg Intake Manifold Absolute Pressure 27.4 in.hg
Engine RPM 676 r/min Engine RPM 676 r/min
Vehicle Speed 0 MPH Vehicle Speed 0 MPH
Intake Air Temperature 70 F Intake Air Temperature 70 F
Air Flow Rate From Mass Air Flow Sensor 3.06 lb/min Air Flow Rate From Mass Air Flow Sensor 3.06 lb/min
STEVE TDG MAFIA#106
post #5 of 13 (permalink) Old 07-31-2009, 06:47 PM
Gone Fishin...
merlin5577's Avatar
The low fuel rail pressure is whats causing your stalling, the question is, whats causing yout low rail pressure....
Is it leaking fuel anywhere?
Cracked fuel lines?
Any smoke coming out of the exhaust?
Fuel in the oil?
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #6 of 13 (permalink) Old 07-31-2009, 09:20 PM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
well if i was a betting man i would say the filter as my buddy probably never has changed it no leaks or cracks knowen ill be working on it tomarrow this last time it just shutdown on the freeway at like 2000 like you turned the key off what kind of fuel pumps do these things have and how much psi should be in the rail?
thanks steve
STEVE TDG MAFIA#106
post #7 of 13 (permalink) Old 07-31-2009, 09:26 PM
Gone Fishin...
merlin5577's Avatar
There is no lift pump, just a suction side on the Cp3. Should have around 26K PSI at the rail.
Yep, a REALLY clogged filter will cause those problems. Filter should be change at least every 15K miles.
Good luck.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
The Following User Says Thank You to merlin5577 For this addition to TDG:
camojeeper (07-31-2009)
post #8 of 13 (permalink) Old 07-31-2009, 09:35 PM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
ya that is what im leaning towards ill swap it out and we shall see
thanks
STEVE TDG MAFIA#106
post #9 of 13 (permalink) Old 08-03-2009, 03:32 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
Update fuel filter had 80,000 miles on it swaped it out and no probs now I told my buddy on our powerstrokes we do em everyother oil change He said OH OK thanks for everyones help(merlin)
STEVE TDG MAFIA#106
post #10 of 13 (permalink) Old 08-03-2009, 03:34 AM
Gone Fishin...
merlin5577's Avatar
For the record, tell your buddy NO MORE then 15K miles between filter changes. Glad you got it fixed.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
HELP 6.5 stalling again josh3434 6.5L Diesel Engine 7 02-11-2008 07:05 PM
stalling rodney960 1994-2003 7.3L Chips & Tuners Forum 8 08-10-2007 04:08 AM
Stalling 1QKBRD 1994-2003 7.3L Power Stroke 7 11-11-2006 12:37 AM
Stalling elkhunter 1994-2003 7.3L Power Stroke 1 10-22-2006 10:11 PM
