time for injectors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cat power, this thread has received 7 replies and been viewed 1399 times.
post #1 of 8 (permalink) Old 08-27-2009, 01:51 AM Thread Starter
smokin duramax
cat power's Avatar
time for injectors
alright im ready to spend some money for some quality injectors and need some input on wat i should get
04 lb7 chevy 2500 Duramax Ext.CSB 4x4 6 speed
Engine : PPE 425 hp chip, Head stud kit, studded mains, dual cp3s, FASS, ATS Aurora 3000 & 5000 , and 5 inch straight pipe.
Transmission : zf6 , dual disc clutch , atlas II transfer case (daily driver)
88 s10 on a 1 ton frame , 350 .30 over 3/4 cam , afr 200cc heads , 800cfm thunder eldbrok , 14 bolt rear dana 60 front , np 205 with a munci m21 4speed tranny . 527 gears. dual radiaters sittin on 44s. ( TOY )
1987 CASE 1455B track loader / crawler loader
1997 CASE 1845C skid steer / bobcat
1990 CASE 580K 4x4 , turbo Backhoe
1968 CAT D9G dozer NEW WIDE TRACKS
1985 CAT D4H dozer High track
1993 CASE 1288 Track hoe / Excavator
1984 CAT D6D dozer
1987 GMC General tri axle dump , 855 cummins pump turned up, 4.88s 9 spd.
1986 GMC BRIGADIER single axle , 6v92 detroit pump turned up, 5.57s 9spd. custom goose neck, tool/welding Bed
1988 chevy C70 CC single dump , 8.3 cummins , 100# fuel plate 9 speed , 6.57s
1990 PETE 375 Dump quad axle , 3406B cat (dumpin the fuel ) , 18spd. 5.13s
2003 Chevy C5500 CC 4x4 duramax , 208wb. 6spd. 4.56s , long flatbed goose neck
300hp ppe chip , Fass, head studs , Aurora 3000, dual disc clutch , 5" straight pipe
cat power is offline
post #2 of 8 (permalink) Old 08-27-2009, 06:28 PM
Pardue the Traveler
New 0mega's Avatar
Well how much power are you planing to make?
Singles Club member #250
New 0mega is offline
post #3 of 8 (permalink) Old 08-27-2009, 09:18 PM Thread Starter
smokin duramax
cat power's Avatar
well i guess around 700 to 800 street truck
1984 CAT D6D dozer
post #4 of 8 (permalink) Old 08-28-2009, 12:53 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
Try out Socal diesel or DDP.... they will be able to help you out
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #5 of 8 (permalink) Old 08-28-2009, 04:21 AM Thread Starter
smokin duramax
cat power's Avatar
alright ill do that thanks
1984 CAT D6D dozer
post #6 of 8 (permalink) Old 08-28-2009, 10:40 AM
DrHolliday's Avatar
I hope your planning on replacing your stock rods to be pushing that kind of power.
Chris
2006 Chevy 2500HD LBZ/Allison ECSB 4x4 Greystone metallic
S475, 3" boost tubes, 5" intake, Custom Y-Bridge
Tuning and Transmission by Diesel Addiction . A special thanks to Dustin for all the help.
12.42 @ 106.3 (stock injectors, CP3, and turbo, no drugs!)
7.83 @ 86.2 1/8th
531 RWHP / 940 RWTQ 10/11/08 on Wayne's Dyno in Jville NC
USMC 2002-present
DrHolliday is offline
post #7 of 8 (permalink) Old 08-29-2009, 05:43 AM Thread Starter
smokin duramax
cat power's Avatar
well i havent realy thought about that . but if i tear it down i might as well put pistons and get the heads worked and any thing else i should do while im at that stage
1984 CAT D6D dozer
post #8 of 8 (permalink) Old 08-29-2009, 05:57 PM
CRAZY CANUCK
Socal 7.1L stroker Kit... if your gonna go that far might as well make it a runner
Ridin Dirty Club #5
TDG TOTQ
One time deal, injectors, Termy, Fluidampr. mech2161 Whats Been Sold 3 06-08-2009 01:56 PM
I pretty sure its time for new injectors. SmokingIDI_7.3L 7.3L and 6.9 IDI (Pre 1994) 8 07-11-2007 10:45 PM
Long time Diesel driver, first time poster FireHunter Introductions 11 12-05-2006 07:00 PM
Hello, long time listener first time caller... Oliverpuller Introductions 14 11-16-2006 08:08 PM
1/4 mile time w/ injectors? DEERSNIPER 5.9L Cummins (2003-2007.5) 6 02-06-2006 04:32 PM
