low coolant level - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by woodyh61, this thread has received 9 replies and been viewed 6737 times.
post #1 of 10 (permalink) Old 08-28-2009, 03:20 AM Thread Starter
low coolant level
2004 low coolant level comes on and antifreeze , and i can not see any place it is leaking from. this has been going on about
a week now, probably put about a gallon in . any ideas guys?
woodyh61 is offline
post #2 of 10 (permalink) Old 08-28-2009, 04:35 AM
Gone Fishin...
merlin5577's Avatar
Only one of two things can be happening, its leaking or burning it. Are you noticing any excessive amount of water out of the tailpipe? or any wet spots on the ground?
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #3 of 10 (permalink) Old 08-28-2009, 04:38 PM Thread Starter
notice no fluid out the tail pipe, no cream color oil, however i do have a smell of possible over heating, temp gauge stays at 200 degress
woodyh61 is offline
post #4 of 10 (permalink) Old 08-28-2009, 05:22 PM
Pardue the Traveler
New 0mega's Avatar
When was the last time you flushed the system, anti-freeze breaks down over time. Gm recommends flushing the system every 5 years.
Singles Club member #250
New 0mega is offline
post #5 of 10 (permalink) Old 08-28-2009, 11:50 PM Thread Starter
I am new to P.M on diesel's So how do I go about flushing the system? Where do you drain the fluid out?
woodyh61 is offline
post #6 of 10 (permalink) Old 08-31-2009, 12:40 AM
Pardue the Traveler
New 0mega's Avatar
You should pick up some radiator flush and new Gmc duramax compatible coolant.The ethylene glycol in antifreeze has a sweet odour and will attract animals which try to ingest it - it is highly toxic to them. Please do not simply drain your vehicle's antifreeze onto your work surface at all. You should be sure to collect any antifreeze that you drain and dispose of it properly as you would do with engine oil. For proper disposal method, please contact your municipality for details. In most cases, it is acceptable to dump the waste antifreeze down your toilet, flushing often as most water treatment facilities are more than capable of treating the water. This method does not apply to people who rely on septic tanks. The 04's have a radiator drain petcock on the passenger side rear of the radiator. Park it with the motor downhill, open up the petcock and the filler cap then drain as much as you can from that, then pull the lower radiator hose, that should get at least 75% of the fluid. You'll want to put the hose back on and close the petcock and fill the rad with tap water, then drain again. Follow the directions on the Radiator flush container. Follow the directions for the rad fluid. You may also want to clean the trans cooler, oil cooler, inter-cooler (if you got one) and the rad of debris with a low pressure wash.
post #7 of 10 (permalink) Old 08-31-2009, 11:21 PM Thread Starter
Thank you,very much!!!! now fisrt good day of no rain and a dry ground will do
thanks again , i am use to gas rigs not diesel
woodyh61 is offline
post #8 of 10 (permalink) Old 09-01-2009, 05:29 AM
Pardue the Traveler
New 0mega's Avatar
the cooling system is much the same for gas and diesel applications
post #9 of 10 (permalink) Old 09-11-2009, 12:26 AM
jdreda's Avatar
my 03 was doing the same thing for about a year the low coolant would come on and no coolant on the ground but when i would walk past the front of the truck i would have a strong coolant smell. till finally it started to leak on the ground at the back of the engine. what it was doing was slowly drip out the gooseneck and running across the top of the engine and evaporating before it hi the ground until the leak got bigger and hit the ground. all it was, was a fifty cent o-ring.
jdreda is offline
post #10 of 10 (permalink) Old 09-20-2009, 03:56 AM
my 04 is doing the same thing low coolant and i cant find it
blk smoke lb7 is offline
below the min level lee boy 2003-2007 6.0L Power Stroke 7 07-27-2009 07:31 PM
Level 10 MOPSD250 2003-2007 6.0L Power Stroke 9 07-09-2009 11:38 PM
level kit topflight250 1994-2003 7.3L Power Stroke 3 02-24-2009 07:37 PM
Oil Level snopro99 2008-2010 6.4L Power Stroke 17 12-03-2007 03:37 AM
Updated minimum coolant level? imported_LiftedBlackHD 2003-2007 6.0L Power Stroke 1 06-23-2007 06:54 PM
