I need help please, about injector replacement - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by German Frank, this thread has received 3 replies and been viewed 1544 times.
post #1 of 4 (permalink) Old 08-30-2009, 09:47 PM Thread Starter
German Frank's Avatar
Hello at all,
I'm new in your TDG Forum, but I introduce myself in the Introductions Thread.
I expanded on my Silverado Duramax 2001's the 8 injectors and given to the Bosch test center, because the Truck has uncanny smoke.
I received a call that 4 injectors are broken but 3 are repairable. I must have 1 injector for Exchange, the return line kit, seals and so.
Now to my Question. how I purge air from the whole fuel system after Installation of the injectors and the assembly of Engine?
I hope you can help me! and sorry for my bad english.
Thank you!
Greetings from germany
Frank
German Frank is offline
post #2 of 4 (permalink) Old 08-31-2009, 04:03 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
im not entirely sure what your after, however on top of your fuel filter assembly there is a primer button, as well as a bleeder screw, you loosen the bleed screw a small amount, and push down on the primer repeatedly until fuel begins to come out of the bleed screw press the primer a few more times to ensure the air is bled out, and then tighten the screw down, your fuel system should be bled of air, if you have troubles with it not running, repeat the above process
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
German Frank (09-02-2009)
post #3 of 4 (permalink) Old 09-02-2009, 08:09 PM Thread Starter
Thank you for the information.
That's all? I thought we would still have any extra lines or injector pump bleed!
If that does not work, I hope to once again ask for advice.
But this may be a while I have the Injector, Return Line kit, gaskets for the 8 injectors and a few odds and ends in the United States of America to order, as the injector in Germany, 10 to 15 weeks delivery time. I phoned Bosch of Germany, who could not help me. Can you tell me a good shop, which I can supply the parts cheap and fast?
Thanks a lot
Greetings from Germany
Frank
post #4 of 4 (permalink) Old 09-02-2009, 11:45 PM
CRAZY CANUCK
Maybe you could check out the Supporting vendors on this site
https://www.thedieselgarage.com/forum...splay.php?f=37
Post your question in this section, im sure someone will be able to help you out
Ridin Dirty Club #5
TDG TOTQ
Fuel Injector Replacement Program Jus Cruisin 2008-2010 6.4L Power Stroke 8 08-30-2009 08:49 PM
Injector replacement cost sundownbrown 2003-2007 6.0L Power Stroke 7 03-06-2009 12:32 AM
LLY Fuel Injector Replacement (Left) ripmf666 GM Spec Info 0 12-28-2008 12:12 PM
LLY Fuel Injector Replacement (Right) ripmf666 GM Spec Info 0 12-28-2008 11:39 AM
Need help with injector replacement on 05 CTD m3transporter 5.9L Cummins (2003-2007.5) 0 12-15-2007 02:14 AM
