limitation on 2005 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Robts, this thread has received 6 replies and been viewed 998 times.
post #1 of 7 (permalink) Old 10-22-2009, 04:23 PM Thread Starter
Supporting Vendor
Robts's Avatar
limitation on 2005
Since I got rid of my 6l and put a cummins in my ford Im a little gunshy. Im probably buying a 2005 dmax for a towrig/daily driver. Is it safe to put a ppe hot plus 2 in it with engine problems...ie studs. I am already planning on doing a suncoast right away. Also, the truck has propane on it with a chip. Dont know which one. Can I run the hot plus and propane.
Thanks
rob
2004F-SVT Lariat 2005 Cummins 5.9 conversion
August 2007 TDG Truck of the Month
Septmeber 2009 TDG Truck of the Month
2008 TDG Truck of the Year
2005 CR Cummins conversion with destroked motor mounts and tach module.
ARP Studs;Hamilton springs and pushrods
WickedDiesel DragonSlayer CP3 and 5x10.5 inj
Tsperformance MP8; Smarty S06 TNT-R
Speraco Inercooler; Opie Water by-pass;DTT intake elbow
Twin turbos
Grand rock 7" stacks
ATS Stage V 48re Transmission with billet output shaft and Co-pilot
Ford transfer case with ATS input shaft. Thanks to Sogrand for that
4.56 gears with Detroit truetrac. Custom Oasis Diff covers
FarmboyFabrication Ladder bars
(10) Autometer Gauges
6.5" Explorer Procomp lift with Fox Shox
37x13.5x22 Toyos with 22x10 Eagle wheels
2005 front end conversion with McColluch HID lights
Randy Ellias light bar with 4 procomp 130watt lights
Heat exchanger hood; limo tint, recon lights up top and on the mirrors
Optima. Yellow Tops; BilletBadges; Big special thanks to Walley at FTE
My Cummins conversion:https://www.thedieselgarage.com/forum...read.php?t=933
Robts is offline
post #2 of 7 (permalink) Old 10-22-2009, 05:58 PM
Administrator
fordt's Avatar
Images: 5
You won't need studs for a tuner. When I came from a 6L to the LBZ, I told Eric Merchant, the first thing I wanted to do was studs! He laughed. I am not sure about the propane.
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #3 of 7 (permalink) Old 10-22-2009, 07:21 PM
Pardue the Traveler
New 0mega's Avatar
The ppe hot +2 should work with propane but I don't know for sure. You don't need head studs till you make over 700hp on a duramax. If its a 2005 its an LLY not a LB7. You have to be careful about overheating due to a restrictive turbo mouth piece causing the turbo to work harder and starting a vicious cycle, but there is a fix so it's not so bad.
Singles Club member #250
New 0mega is offline
post #4 of 7 (permalink) Old 10-23-2009, 04:37 PM
You will need a lift pump as well to feed the CP3 on the higher tunes on the PPE. Nates lb7 runs out of fuel on the hottest tune without a lift pump. He still beat Ryan though when they raced a few months back ha.
stretch8614 is offline
post #5 of 7 (permalink) Old 10-25-2009, 05:17 PM
Supporting Vendor
Do the trans first. Its the biggest expense.
Second, open the exhaust and intake.
Third, tuning.
As for the trans, your on the right track with the Suncoast.
As for the intake, a LBZ mouthpiece to the front of the turbo as well as a good CAI such as S&B or AFE.
As for the Exhaust, Silverline makes a great product at an affordable price.
Tuning, PPE will work well or a good EFI tune will get you great power and mileage
As for head studs, dont take it the wrong way but you will bend the rods before you lift the heads.
Eric Merchant
www.Merchant-Automotive.com
Zeeland, MI
1-866-399-7169
ASE/GM Master Certified
AC Delco Independent Repair Center
Authorized Suncoast dealer/installer
State of Michigan Licensed Repair Facility
dmaxalliTech is offline
The Following User Says Thank You to dmaxalliTech For this addition to TDG:
New 0mega (10-25-2009)
post #6 of 7 (permalink) Old 10-25-2009, 05:42 PM
TDG Mafia Goon
BombDocDiesel's Avatar
Rob, which propane system is it? Most people run those for mileage but it is additional fuel. I would like to know what it does for your numbers.
When do we see this new DD/tow pig?
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #7 of 7 (permalink) Old 10-25-2009, 05:49 PM
Supporting Vendor
Propane is for grilling
Eric Merchant
Zeeland, MI
1-866-399-7169
6.4 in a 2005 Lil Boosty 2003-2007 6.0L Power Stroke 5 09-03-2009 12:01 AM
2005 f-350 powerstroke7.3 2003-2007 6.0L Power Stroke 1 04-27-2009 10:08 AM
2005 Excursion PS vs. 2005 F-series PS deb0650 2003-2007 6.0L Power Stroke 3 04-07-2007 06:23 PM
My DOA 2005. imported_TubingJon 2003-2007 6.0L Power Stroke 9 04-11-2006 09:06 AM
Ttc 2005 Deezle1 The Parking Lot 7 12-07-2005 12:48 AM
