Is This a good deal??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PaleRider, this thread has received 8 replies and been viewed 1078 times.
post #1 of 9 (permalink) Old 10-28-2009, 03:35 AM Thread Starter
Gettin By
PaleRider's Avatar
I found a 04 2500 CC LT 4x4 w/ 42000 for 26,000. How do I know if is a LLY or LB7 sticker on the B piller 3/04? What should I be on the look out for? I will pull the trigger if this is a good truck. I pull a 5w & boat in the summer with a 08 F350 but need better MPG now, this will become my daily driver since I'm turning in my company truck. What should I expect for MPG? Oh the truck is at a ford dealer.
PaleRider
___________
2008 Job #3 F-350 XLT, CC, SB, SRW 4x4. 2" Leveling Kit, AIR LIFT Bags & PuLLRite 18K Hitch & SCT Tuned
R.I.P. 2001 F-250 7.3 Stolen & Burnt To The Ground!
UNION CLUB # 13
PaleRider is offline
post #2 of 9 (permalink) Old 10-28-2009, 04:58 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
sounds a little pricey, i would say 22-23k..... tops, that should be a LB7, and they usually get 17-18mpg unloaded
the only problems are with the injectors, but being that is a low mileage 04 you have over a year and 160000miles left on the injector warranty, you may not like the down grade in power, but any simple tuner can give you an extra 50-60hp with no problems
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
PaleRider (10-28-2009)
post #3 of 9 (permalink) Old 10-28-2009, 04:25 PM
Pardue the Traveler
New 0mega's Avatar
If you can talk the dealer down then I'd say go for it where you buy it doesn't matter as long as you get a good deal..
Singles Club member #250
New 0mega is offline
post #4 of 9 (permalink) Old 10-28-2009, 05:04 PM
TDG Mafia Goon
BombDocDiesel's Avatar
As the brothers mentioned injectors could be an issue and you definitely want to talk down some. He's trying to milk that for almost every bit of retail. There is always wiggle room in used vehicles at a dealership.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #5 of 9 (permalink) Old 10-29-2009, 03:00 AM
CRAZY CANUCK
you can run a programmer like the PPE xcelerator economy, or the Diablosport Predator can get an LB7 up to about 350rwhp at the highest levels
Ridin Dirty Club #5
TDG TOTQ
post #6 of 9 (permalink) Old 10-29-2009, 03:23 PM
Cummins Tower
Cwalt's Avatar
pretty sure its an lb7
-Cliff
"You know you wanna win the round, So when that brindle comes around, You better cok your hammer down, Don't quit till you head hits the ground, Go on and lift that leg and spur
You gotta get up in the neck, Step off and pick up your check" - Colby Yates
06 chevy silverado 2500hd duramax work done by dieseljunk.com!!
02 gmc sierra 2500hd duramax. if you only knew work done by dieseljunk.com!!
09 appalachian 24ft gooseneck trailer
Cwalt is offline
The Following User Says Thank You to Cwalt For this addition to TDG:
PaleRider (10-29-2009)
post #7 of 9 (permalink) Old 11-04-2009, 10:23 PM
Toyaholic
If the vin code is "1", its an LB7
01 Chevy CC/SB 4WD. Not Quite Stock.
vrabel is offline
post #8 of 9 (permalink) Old 11-05-2009, 12:44 AM
TDG Mafia Goon
If the 8th digit is 2 it's an LLY.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #9 of 9 (permalink) Old 11-05-2009, 01:25 AM
Supporting Vendor
Sounds like alot of money to me
Eric Merchant
www.Merchant-Automotive.com
Zeeland, MI
1-866-399-7169
ASE/GM Master Certified
AC Delco Independent Repair Center
Authorized Suncoast dealer/installer
State of Michigan Licensed Repair Facility
dmaxalliTech is offline
F700 with 12V 5.9L - is this a good truck & a good deal? Michael Medium and Heavy Duty 11 03-06-2008 01:12 AM
Good Deal? Notorious6.0 2003-2007 6.0L Power Stroke 7 02-19-2008 02:24 PM
Does this seem like a good deal? Duke 5.9L Cummins 12 Valve (1994-1998.5) 13 12-29-2007 09:51 PM
Good deal Dual K20s 5.9L Cummins 12 Valve (1994-1998.5) 3 08-24-2007 12:56 AM
Good Deal or Bad Deal?? Notorious6.0 General Ford Truck and Excursion 18 09-09-2006 07:21 PM
