Edge Juice With Attitude Problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2500HD03, this thread has received 3 replies and been viewed 8678 times.
post #1 of 4 (permalink) Old 10-29-2009, 05:03 PM Thread Starter
I recently bought and Edge Juice with attitude off of ebay. I was told the item worked when removed. I plugged it in and it worked then screen went blank and it would not display rpm or any parameters, just o. The display worked right just no rpm, temps, or power level in the box would not change. Took connections apart and found that there were several terminals that were missing the mating terminal. I put grease in there and adjusted things untill i could see that it was mating correctly. Now i start it up and it reads everything right and adjusts power levels right but once display turns on it will go blank after exactly ten sec. every time. When the display goes blank i can tell it is not just a display issue because i dont have any extra power either. I set on five before display shut down and drove and it was just normal. I called edge and talked to them but they just said it was probly bad. I think it is weird though that it will shut down after exactly 10 sec. every time. this seems more like maybe another wire issue. Has anyone ever seen this?
03 2500HD CC, SB, 4X4
STOCK OTHER THAN A GUTTED MUFLER
2500HD03 is offline
post #2 of 4 (permalink) Old 10-29-2009, 11:54 PM
Gone Fishin...
merlin5577's Avatar
Its most likely broken. The programmer is shutting down after 10 seconds because it cant connect with the trucks computer. Sorry to be the bearer of bad news.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #3 of 4 (permalink) Old 10-30-2009, 02:05 AM
elkhunterr81's Avatar
Ouch.. was it from a shop? can you return it atleast?
elkhunterr81 is offline
post #4 of 4 (permalink) Old 10-30-2009, 05:45 AM Thread Starter
K I'm going to check the other connector again. No I got it off of ebay from someone that said it worked i contacted him and let him know what the issue was and he is not replying back now. It must be connecting to the ecu for that 10 sec though because it is reading parameters for rpm, coolant temp, gear and such though. Edge said i can send it in to them and they will discount me a new chip because this unit is one that is unrepairable due to how it was made. There offer is decent only 536 for a brand new juice attitude that is upgradeable. however i paid 220 for the unit and had to buy a probe for 50. so that is right at 800. Witch is not worth it to me.
2500HD03 is offline
Edge Juice w/ Attitude Turbo cool down problems Taylor34 5.9L Cummins (1998.5-2002) 3 02-05-2009 01:03 AM
edge juice with attitude jay couch 1994-2003 7.3L Power Stroke 4 04-25-2007 12:44 PM
Edge Drag Comp vs. Edge Juice/Attitude lbdodge24v 5.9L Cummins (1998.5-2002) 12 03-08-2007 08:31 PM
Edge juice W\Attitude problems AGAIN!!!! SmokingIDI_7.3L 1994-2003 7.3L Chips & Tuners Forum 3 12-02-2006 12:22 AM
Edge juice W\Attitude problems SmokingIDI_7.3L 1994-2003 7.3L Chips & Tuners Forum 10 11-10-2006 05:30 AM
