Rust in injector inleys - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ewales, this thread has received 3 replies and been viewed 1144 times.
post #1 of 4 (permalink) Old 11-03-2009, 03:14 AM Thread Starter
Rust in the injector inlets
Hello
I have a situation with rust packed in the injector inlet's on an 02 Duramx. I have heard that GM has a bulletin about this, but I have not been able to find it. Does anyone know anything about this.
Thanks
ewales is offline
post #2 of 4 (permalink) Old 11-03-2009, 08:43 PM
Gone Fishin...
merlin5577's Avatar
GM has a bulletin out for injector troubles but I dont beleive its about rust. The injector warranty on the LB7 is 7 years/200K so you might still be under warranty but probably not.
How did the rust get into the fuel system? Did the truck sit for a long time? The fuel filters on these trucks are very good at pulling junk out.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #3 of 4 (permalink) Old 11-04-2009, 06:22 PM
Pardue the Traveler
New 0mega's Avatar
did the truck have head gasket problems? cause I've heard that coolant and oil can leak at the injectors and that might be the cause of the rust now.
Singles Club member #250
New 0mega is offline
post #4 of 4 (permalink) Old 11-05-2009, 01:32 AM
Supporting Vendor
The rust is not IN the fuel system.
The rust is from the line. Moisture collects around the nut and as you remove the fitting from the injector, it all falls into the inlet of the injector. A proper fix would be to take a small bead of silicone and seal the area between the hex and the line. This will prevent moisture and debris from collecting in there.
Eric Merchant
www.Merchant-Automotive.com
Zeeland, MI
1-866-399-7169
ASE/GM Master Certified
AC Delco Independent Repair Center
Authorized Suncoast dealer/installer
State of Michigan Licensed Repair Facility
dmaxalliTech is offline
The Following 2 Users Say Thank You to dmaxalliTech For this addition to TDG:
BriteWhiteRam (11-06-2009), merlin5577 (11-05-2009)
Rust...? Paste42 5.9L Cummins (2003-2007.5) 1 02-16-2009 02:08 PM
Where's the rust? Rcannon General Ford Truck and Excursion 6 06-28-2007 08:17 PM
Rust on oil pan imported_99powerstroke 1994-2003 7.3L Power Stroke 3 09-07-2006 02:19 AM
Rust!!! Greyhorse Medium and Heavy Duty 5 12-29-2005 10:09 PM
Rust BROKER 5.9L Cummins (2003-2007.5) 2 06-13-2005 12:53 AM
