2 stroke oil in a Duramax? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by merlin5577, this thread has received 46 replies and been viewed 18334 times.
post #1 of 47 (permalink) Old 11-11-2009, 01:21 AM Thread Starter
Gone Fishin...
merlin5577's Avatar
Anyone running 2 stroke in their Duramax? Comments good or bad? Impressions?
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #2 of 47 (permalink) Old 11-11-2009, 04:24 AM
elkhunterr81's Avatar
I have tried it.Used it for 5 or 6 tanks in a row. I didnt stick with it. I used castor 927. maily cause i had alot of it from my banshee. the only difference i noticed was a very slight quiter idle. I often run the marvels mystery oil and i do notice a little difference in fuel mileage with that. I am curious if and what others noticed. Maybe a different brand of 2 stroke oil is more beneficial?
elkhunterr81 is offline
post #3 of 47 (permalink) Old 11-11-2009, 05:52 PM
i use the low ash 2 stroke oil 1 gallon from walmart and i did notice the engine runs quiter and is good for the injecters. there was a test on diesel power that showed a gain in fuel economy
CHORIZOSDMAX is offline
The Following User Says Thank You to CHORIZOSDMAX For this addition to TDG:
merlin5577 (11-19-2009)
post #4 of 47 (permalink) Old 11-11-2009, 10:58 PM
bad1's Avatar
Oil
Tried Stihl 2 stroke oil but I did not notice any difference so switched to the fuel conditioner John Deere sells,not sure the name of it off the top of my head but there is a summer and winter additive.I find it works because if I miss adding it, it throughs P0089 code.
bad1 is offline
post #5 of 47 (permalink) Old 11-11-2009, 11:58 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
um not adding an additive should not be throwing any codes.... the duramax engine is designed to run on USLD, even the older ones
2-stroke oil IMHO doesn't do enough to make a big difference, or be worth the effort/expense of doing it, because you have to be very precise when you add it, you cant add too much or too little, PITA because its more crap you have to carry around in your truck, in the winter you could run an anti-gel just to protect against fuel waxing, but i dont see the benefits of additives, you can get more lubricity out of some B5 biodiesel
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #6 of 47 (permalink) Old 11-12-2009, 03:14 AM
Toyaholic
a qt of atf to full tank from time to time does a good job cleaning fuel system.
01 Chevy CC/SB 4WD. Not Quite Stock.
vrabel is offline
post #7 of 47 (permalink) Old 11-12-2009, 03:28 AM
I 100% disagree... ATF contains friction modifier. Which means you are putting very small sand like particles through your motor
post #8 of 47 (permalink) Old 11-12-2009, 03:39 PM
Toyaholic
doin it for over 20yrs with no issues.
vrabel is offline
post #9 of 47 (permalink) Old 11-13-2009, 02:05 AM
I would say that is a pretty good run..
post #10 of 47 (permalink) Old 11-13-2009, 02:16 AM
M123KT-450's Avatar
Yikes !
2 stroke oil i tired running that in my trucks along with the ATF and MMO as well. . .
I used AMSOIL 2 stroke oil and AFT i noticed nothing so then i tired Super tech 2 stroke n AFT noticed nothing then i tried a few bottles worth of MMO and again noticed nothing. . .
So 2 brands of AFT n 2stroke no effect on any of my diesels and 2 or 3 big bottles of marvels all of which didn't do a thing for me. . .
59' END+T 711.
75' ENDT 676.
84' Ford 7.8L.
95' GM 6.5L.
97' 8.3L-CTD.
08' 6.7L-CTD.
6 truck truck's 6 different engines years mileages uses ECT.
Now i did how ever notice the larger truck's started faster and had better throttle response running the AMSOIL diesel lubricant fuel additive. . .
EDIT:
now that might be an additive you guys might want to try. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
two stroke oil? maltby4459 5.9L Cummins (1998.5-2002) 9 04-16-2009 03:09 AM
2 stroke oil Taylor34 General Ford Truck and Excursion 15 03-23-2009 08:33 PM
2 stroke oil BriteWhiteRam 5.9L Cummins (2003-2007.5) 46 02-16-2008 10:46 PM
Duramax vs 6.0 power stroke harley250 Duramax 2006-2007(LBZ & LLY) 45 04-09-2007 12:29 AM
2 stroke or 4 stroke!? Deezle1 4X4 Offroad Forum 25 11-27-2005 02:31 AM
