trans slips when it shifts...need help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by turfin8705, this thread has received 4 replies and been viewed 860 times.
post #1 of 5 (permalink) Old 11-23-2009, 02:49 AM Thread Starter
Diesel Addict
turfin8705's Avatar
what would cause the trans to slip between shifts but if you smash the throttle the trans doesnt slip...and its not the defueling that im talking bout its a definate slip then it grabss...ive checked the fluid levels and all...
2002 Chevy Silverado 2500hd ec/lb 4x4, efi live with built transmission , k&n intake, Dual 5 inch stacks, intake horn mod, 315/75/16 Kuhmo Road Venture M/T.
turfin8705 is offline
post #2 of 5 (permalink) Old 11-24-2009, 01:11 AM
elkhunterr81's Avatar
between 4th to 5th gear?
elkhunterr81 is offline
post #3 of 5 (permalink) Old 11-24-2009, 01:42 AM Thread Starter
Diesel Addict
turfin8705's Avatar
no every gear....i changed the spin on filter n pulled the trans pan found metal shavings in there...i changed the internal filter also...seemed to help since the filters were probably clogged but it looks like my converter or something else is comeing apart...its still drivable but it wont be long....
post #4 of 5 (permalink) Old 11-24-2009, 03:40 AM
Pardue the Traveler
New 0mega's Avatar
You need a trans job and fast
Singles Club member #250
New 0mega is offline
post #5 of 5 (permalink) Old 11-24-2009, 03:41 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
well the Quadzilla would be whats causing your slip......... the allison in stock form takes nothing past 100hp... i would say 80hp is the safe limit, if your slipping it and finding metal shavings in your pan then im gona say that you need a rebuild ASAP, your on borrowed time friend, your gona need a new tq-converter, steels and frictions, Valve-body, and bands.... and a check over to see what other damage has been done
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
4.10's, factory limited slips, wheels/tires... 03f3507.3 Ford Parts 9 10-20-2009 11:34 PM
suncoast trans shifts twice each gear???? nick0360 2003-2007 6.0L Power Stroke 2 06-12-2009 06:19 PM
Post the weights slips of your 250/350. TANK'S 250 The Parking Lot 30 03-31-2009 03:54 PM
cold transmission slips every morning dodgedawg 5.9L Cummins 12 Valve (1994-1998.5) 14 03-08-2008 02:15 AM
Hp from 1/8 mile slips jello 2003-2007 6.0L Power Stroke 6 08-08-2006 03:35 AM
