block heater location - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by elkhunterr81, this thread has received 8 replies and been viewed 16630 times.
post #1 of 9 (permalink) Old 12-10-2009, 03:29 AM Thread Starter
elkhunterr81's Avatar
I was trying to find my block heater tonight. My truck still fires right over but its been no warmer than 35 here over the past week. I thought it was supposed to be passenger side right below the exhaust manifold. I could not locate it.
Thanks
Jamie
elkhunterr81 is offline
post #2 of 9 (permalink) Old 12-10-2009, 05:32 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
i know the cord on mine comes out on the passenger side, ive never gone looking for it however, you dont need to plug it in until the temps are about -10f
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
elkhunterr81 (12-11-2009)
post #3 of 9 (permalink) Old 12-11-2009, 12:25 AM
Toyaholic
From the factory, the cord is rolled up and taped to harness on pass wheel well. follow cables from battery. plug should be all taped up to for protection. The heater itself is a freeze plug next to motor mount.
01 Chevy CC/SB 4WD. Not Quite Stock.
vrabel is offline
The Following User Says Thank You to vrabel For this addition to TDG:
post #4 of 9 (permalink) Old 12-11-2009, 01:52 AM Thread Starter
It has done great so far, Guess ill worry about if it if it gets below 0. Odd my wifes power stroke does ALOT better when plugged in below 40. Mine has been the same so far.
post #5 of 9 (permalink) Old 12-11-2009, 03:00 AM
Gone Fishin...
merlin5577's Avatar
I dont plug mine in unless the temperature is going to be around 0* or lower.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #6 of 9 (permalink) Old 12-11-2009, 01:21 PM
Toyaholic
I never had to plug in for starting. even for below zero. Just for some heat for days I leave before sun comes up.
vrabel is offline
post #7 of 9 (permalink) Old 12-11-2009, 01:46 PM
CRAZY CANUCK
I have started my lbz in temps around the -35 to -40f mark without being plugged in, all i needed to do was cycle glow plugs twice and it started up, it was very very grumpy, but it started, i dont plug mine in until -10f, otherwise i dont see a need to, hit the command start 5-10 mins before i leave and shes nice and toasty, plus it gives the Allison a chance to warm up a bit before i take off
Ridin Dirty Club #5
TDG TOTQ
post #8 of 9 (permalink) Old 12-11-2009, 03:55 PM
I plug mine in for about an hour, at home, when it is freezing to 0F it is cheaper to warm it up with electricity than the wear and tear and diesel. I leave it plugged in till I am ready to go, usually within a couple of minutes, again electricity is cheap.
Johnp3 is offline
post #9 of 9 (permalink) Old 12-11-2009, 04:33 PM
CRAZY CANUCK
i didnt say it was a good thing to start it being that cold, i have mine plugged in right now and the current outside temp is -6.4f, it will start much easier and heat up much quicker
Ridin Dirty Club #5
TDG TOTQ
Block heater FFRyan 2003-2007 6.0L Power Stroke 5 11-07-2009 10:46 PM
Block Heater location? Waz 6.0 Duramax 2006-2007(LBZ & LLY) 4 02-02-2009 05:06 AM
6.7 Block Heater Cord Location? fflarry 6.7L Cummins (2007.5-2011) 3 08-16-2007 07:57 PM
Block heater wastedwagesracing 2003-2007 6.0L Power Stroke 13 06-30-2006 03:27 PM
block heater ripping r. General Dodge Discussion 5 12-11-2005 03:14 AM
