ppe hot +2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dbeach, this thread has received 15 replies and been viewed 1463 times.
post #1 of 16 (permalink) Old 12-14-2009, 06:43 PM Thread Starter
ppe hot +2
I have heard that on the 425 tune you have to run dual cp3's is that true?
dbeach is offline
post #2 of 16 (permalink) Old 12-14-2009, 06:54 PM
Inline Junky!
Sledpuller500's Avatar
Images: 121
If you wanna get the most of the tune you have too! The 425 tune calls for so much fuel a stock cp3 can't supply and maintain the proper rail pressure. And when your rail pressure drops the spray pattern of your injectors changes from an atomized spray to larger drops that dont burn well and cause cylinder temps (egt) to go through the roof!! Running a risk of melt down. Will it run? yes! Will it run well? No...
Sledpuller500 is offline
post #3 of 16 (permalink) Old 12-14-2009, 08:18 PM Thread Starter
Could you put in a modified cp3 and be good? Do you need to put dual cp3's?
dbeach is offline
post #4 of 16 (permalink) Old 12-14-2009, 08:26 PM
Inline Junky!
Images: 121
I think a modified would get you closer to what you need but i ultimately its hard to beat what dual fuelers can provide you!!
post #5 of 16 (permalink) Old 12-15-2009, 06:56 AM
Pardue the Traveler
New 0mega's Avatar
A lift pump will help the Cp3 but since you want to run the 425hp ppe hot +2 the duel Cp3's are the way to go plus the lift pump.
Singles Club member #250
New 0mega is offline
post #6 of 16 (permalink) Old 12-15-2009, 06:01 PM
smokin duramax
cat power's Avatar
p pumped dmax lol
04 lb7 chevy 2500 Duramax Ext.CSB 4x4 6 speed
Engine : PPE 425 hp chip, Head stud kit, studded mains, dual cp3s, FASS, ATS Aurora 3000 & 5000 , and 5 inch straight pipe.
Transmission : zf6 , dual disc clutch , atlas II transfer case (daily driver)
88 s10 on a 1 ton frame , 350 .30 over 3/4 cam , afr 200cc heads , 800cfm thunder eldbrok , 14 bolt rear dana 60 front , np 205 with a munci m21 4speed tranny . 527 gears. dual radiaters sittin on 44s. ( TOY )
1987 CASE 1455B track loader / crawler loader
1997 CASE 1845C skid steer / bobcat
1990 CASE 580K 4x4 , turbo Backhoe
1968 CAT D9G dozer NEW WIDE TRACKS
1985 CAT D4H dozer High track
1993 CASE 1288 Track hoe / Excavator
1984 CAT D6D dozer
1987 GMC General tri axle dump , 855 cummins pump turned up, 4.88s 9 spd.
1986 GMC BRIGADIER single axle , 6v92 detroit pump turned up, 5.57s 9spd. custom goose neck, tool/welding Bed
1988 chevy C70 CC single dump , 8.3 cummins , 100# fuel plate 9 speed , 6.57s
1990 PETE 375 Dump quad axle , 3406B cat (dumpin the fuel ) , 18spd. 5.13s
2003 Chevy C5500 CC 4x4 duramax , 208wb. 6spd. 4.56s , long flatbed goose neck
300hp ppe chip , Fass, head studs , Aurora 3000, dual disc clutch , 5" straight pipe
cat power is offline
post #7 of 16 (permalink) Old 12-15-2009, 08:22 PM Thread Starter
I have never heard of that is that even possible?
dbeach is offline
post #8 of 16 (permalink) Old 12-15-2009, 08:33 PM
Inline Junky!
Images: 121
enough money can make anything happen... but no.
post #9 of 16 (permalink) Old 12-16-2009, 01:21 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
why would you change a Dmax to mechanical injection???? Dual CP3's are going to make the truck run a whole lot better, a modified pump just isnt gonna keep up if your throwing that much fuel at it
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #10 of 16 (permalink) Old 12-16-2009, 05:50 PM Thread Starter
okay because a p pump is for a 6 cylinder so I could not see how it would work and why would you even do that dual cp3's would be so much easier.
dbeach is offline
