exhuaust leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by michas80, this thread has received 2 replies and been viewed 634 times.
post #1 of 3 (permalink) Old 12-24-2009, 05:01 AM Thread Starter
exhuaust leak
I have a 2003 lb7 with 5 inch exhaust and it sounds like i have a exhuast leak and was just wondering if anyone has had any problem with the exhaust manifold leaking, let me know thanks.
michas80 is offline
post #2 of 3 (permalink) Old 12-26-2009, 11:36 PM
Could be a leak at the uppipe flanges, or the EGT sender is leaking, or you have a cracked manifold or an uppipe bellow burst, or the Vband at the downpipe isnt connected tightly, or you have a leak at a joint (did you use band clamps?).
As you can see, theres just too many variables for someone who's not there to figure it out.
You need to narrow down where you are hearing the leak from and start inspecting.
TheBac is offline
post #3 of 3 (permalink) Old 12-27-2009, 02:02 PM Thread Starter
ok,thanks, ya i have band clamps, it is all welded just not where i cut my muffler out, so ill have to do some looking under there for sure, thanks
michas80 is offline
top end oil leak....??? paulkeith 1994-2003 7.3L Power Stroke 4 02-23-2009 01:08 AM
Oil Leak Rusty-Carlton 1994-2003 7.3L Power Stroke 3 10-31-2007 08:11 PM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 04:17 AM
Oil Leak in X. cdiesel 1994-2003 7.3L Power Stroke 15 01-03-2007 10:03 PM
Exhuaust Back Pressure Sensor lukesdiesel 2003-2007 6.0L Power Stroke 9 09-22-2005 12:46 AM
