Injectors again? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bubba_700, this thread has received 4 replies and been viewed 1653 times.
post #1 of 5 (permalink) Old 01-07-2010, 02:59 AM Thread Starter
Injectors again?
My 03 has 140k on it....all 8 injectors were replaced under warranty at 89k miles Now i got 3 out again. I have a PPE Excelerator on it 225hp max I usually daily drive on 180hp tune. Have a built tranny just curious to why injectors took a sh*t or is it something I did. Have stacked an Edge Juice with Attitude on it once for a local memorial drag race. Any ideas or just bad injectors?
bubba_700 is offline
post #2 of 5 (permalink) Old 01-07-2010, 06:29 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
well the reason the injectors go is because the injector bodies actually crack, causing fuel to dump down the cylinders, as well as in the valve covers mixing with the motor oil
as far as i have gathered the injectors are just inherently weak and crack on their own accord, however i highly recommend that you never "stack" the edge on your truck again, the edge runs injection timing, and the PPE will as well unless you turn it off, these trucks dont like a whole lot of timing on a stock engine, and the LB7 injectors aren't strong
the edge is an "inline tuner" and what it does is interrupt the injectors signals before they reach the ecm, alter the the signal and fool the ECM into providing more fuel and injection timing
the PPE is a "programmer" and it actually changes the ECM programming itself so as to provide your with your extra fuel and timing
so when you run them together you already have an agressive tune in the ECM from the PPE, and then the Edge is sending false signals to the ECM that its still "stock" even tho its modified, so you have both tunes doing two different things
that could be why your injectors took a chit
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
bubba_700 (01-07-2010)
post #3 of 5 (permalink) Old 01-07-2010, 05:28 PM Thread Starter
Hey thanks for the insight! I know what you mean bout the timing i turned timing off on the PPE and let the Edge do it's thing. Know anything about Pensacola Diesel? thinking of trying some of there Injectors....
post #4 of 5 (permalink) Old 01-07-2010, 07:18 PM
CRAZY CANUCK
i dont know anything about Pensicola, infact i really dont know much about aftermarket injectors at all.... i know that DynomiteDieselPerformance sells injectors that are pretty high quality, but im not sure if they have Dmax products, as well Industrial Injection has Injectors as well, you may wana check them out as well
Ridin Dirty Club #5
TDG TOTQ
post #5 of 5 (permalink) Old 01-14-2010, 02:26 PM
I take it your injector changeout was about 3 years ago, based on the mileage? If so, they had not yet switched to the new-style hardened ball/seat, which may finally help the problems.
Cracked bodies were a big issue on the earliest sets (01/02), but not so much on later years (03/04). I think that was one of the first things Bosch had to change was their metallurgy on the bodies.
Pennsacola did alright when they started out, but their reputation has been taking a lot of hits lately. People will install 8 and have 4 out of spec, right out of the box. Its almost as if Pennsacola doesnt even test the injectors before they leave the building. I wouldnt use them.
TheBac is offline
Looking for a set of 250 cc or bigger injectors in trade for my II 185 cc injectors mikes06lariat Ford Parts wanted 1 08-12-2009 02:52 AM
Injectors 91rangerturbo Common Rail 15 02-09-2009 03:01 AM
Performance Injectors Or Stock Injectors imported_Stroker01 1994-2003 7.3L Power Stroke 8 05-06-2008 04:16 PM
how big injectors? quattroroad Common Rail 10 05-05-2008 03:33 AM
Help Injectors?????? strokedout_07 2003-2007 6.0L Power Stroke 18 04-20-2007 04:20 AM
