Aftermarket Injectors/Injector Nozzles - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stroker smoker_lb7, this thread has received 3 replies and been viewed 2441 times.
post #1 of 4 (permalink) Old 01-25-2010, 04:40 AM Thread Starter
Images: 3
Send a message via AIM to stroker smoker_lb7
What are you all running and how does it run? I am looking at the ATS 165Horse Nozzles. Any thoughts?
02 Silverado 2500HD 6.6 Duramax- AFE Intake, Quadzilla Stealth 2, Bully Dog DynoDominator, PPE Boost Valve, Single 6 inch Black Turn back Stack, Stewart Warner Gauges
stroker smoker_lb7 is offline
post #2 of 4 (permalink) Old 01-25-2010, 03:19 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
only thing i can tell you is that your gona need a lift pump, and an extra cp3 if you want to run injectors that big, otherwise you'll drain your rails in a hurry and it will fall flat on its face...
the reason most guys dont kick in bigger sticks is the duramax when properly tuned can churn out up to 500rwhp without them...
ATS is one of the biggest aftermarket diesel companies out there, their injectors cant be all bad can they?
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 4 (permalink) Old 01-31-2010, 12:06 AM
Toyaholic
I have Big Dipper 40% tips. LBZ CP3 modded FPR. and an AirDog in the future.
01 Chevy CC/SB 4WD. Not Quite Stock.
vrabel is offline
post #4 of 4 (permalink) Old 02-01-2010, 03:24 PM
DrHolliday's Avatar
Not sure how they do their injectors to balance them, but I'd stick with a set of balanced injectors that are matched with the tips for even flow in every cylinder. With bigger injectors I would recommend a built trans, fuel pump upgrades, a different turbo, EFI live to tune the truck properly with the injectors. then you'll be all set!
Chris
2006 Chevy 2500HD LBZ/Allison ECSB 4x4 Greystone metallic
S475, 3" boost tubes, 5" intake, Custom Y-Bridge
Tuning and Transmission by Diesel Addiction . A special thanks to Dustin for all the help.
12.42 @ 106.3 (stock injectors, CP3, and turbo, no drugs!)
7.83 @ 86.2 1/8th
531 RWHP / 940 RWTQ 10/11/08 on Wayne's Dyno in Jville NC
USMC 2002-present
DrHolliday is offline
Injector nozzles? cummins0488 5.9L Cummins (2003-2007.5) 6 01-07-2010 02:38 PM
Injector Nozzles Brand-Xrugger 5.9L Cummins (1998.5-2002) 20 06-04-2009 04:38 PM
Edge injector nozzles Robs 03 5.9L Cummins (2003-2007.5) 0 07-21-2007 07:08 AM
Injector nozzles. BogginF350 2003-2007 6.0L Power Stroke 4 04-28-2007 08:32 PM
injector nozzles? 99 CTD 5.9L Cummins (1998.5-2002) 10 07-05-2006 08:29 PM
