manual for automatic 5 sp allison - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dux2bux, this thread has received 7 replies and been viewed 1613 times.
post #1 of 8 (permalink) Old 01-31-2010, 10:06 PM Thread Starter
I am looking for a repair manual for an automatic 5 sp allison with transfer case. I need to do some repairs on the transfer case and would like to look at a manual before I attempt this feat. Thanks.
03 Chevy Silverado 2500 HD, K/N intake, PPE boost fooler, Edge hot juice w/monitor, 4" MBRP turbo back exhaust, Line X bed lining, B/W turnover hitch, Merchant Automotive xfer case pump upgrade
Dux2bux is offline
post #2 of 8 (permalink) Old 02-01-2010, 11:56 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
what do you need to do to the transfer case?
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
Dux2bux (02-03-2010)
post #3 of 8 (permalink) Old 02-02-2010, 12:12 AM
TDG Mafia Goon
BombDocDiesel's Avatar
ATSG Website
http://atsg.com/cart/index.php?p=cat...ison&x=83&y=11
or
Makco
http://www.bulkpart.com/Merchant2/me...=&Store_Code=2
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
The Following 2 Users Say Thank You to BombDocDiesel For this addition to TDG:
BriteWhiteRam (02-02-2010), Dux2bux (02-03-2010)
post #4 of 8 (permalink) Old 02-03-2010, 12:29 PM Thread Starter
I am figuring a bearing has gotten really sloppy and is almost shot allowing the gear or chain inside to rub the side of the housing causing a hole in the side about 2cm big. I can grab the drive shaft near the extension housing and move it a little(up and down) so something isn't right inside.
Dux2bux is offline
post #5 of 8 (permalink) Old 02-03-2010, 04:57 PM
TDG Mafia Goon
You have pump rub! The wear clip has rubbed a hole in the magnesium case. Somewhat common.
Eric has an affordable fix.
http://www.merchant-automotive.com/t...pgradekit.aspx
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
The Following User Says Thank You to BombDocDiesel For this addition to TDG:
Dux2bux (02-04-2010)
post #6 of 8 (permalink) Old 02-04-2010, 10:37 AM Thread Starter
Thank you sooooo much, never would have thought of looking there. Now it's the only place I will look for parts. That is exactly what it is. Good description of problem right next to the parts. Awesome!!
Dux2bux is offline
post #7 of 8 (permalink) Old 02-04-2010, 01:16 PM Thread Starter
With this running low on fluid what would be the possible issues that will most likely need addressed? Do you think all the bearings need replaced, planetary gear or others? I will need to order all the stuff before I dig into it so I only have to do it once. one thing I noticed when I placed it in 4X4 after about 10 sec in motion there was a thunking noise that acted like a bad u-joint but both were replaced already and in good shape. Does that sound like something with planetary unit?
Dux2bux is offline
post #8 of 8 (permalink) Old 02-04-2010, 03:24 PM
TDG Mafia Goon
Most people can fix the pump rub and keep going. I recommend switching to 5w-30 or 0w-30 synthetic motor oil in cases. ATF has great hydraulic pressure and heat transfer properties but a transfer cases needs lubrication.
If you drain and remove the case and put it through it's range by hand, if it feels loose or grinds you may need to replace the bearings. I would contact SoGrand https://www.thedieselgarage.com/forums/member.php?u=309 I went trhough him when I needed parts and he was great to work with.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
Allison hd automatic Scubba Medium and Heavy Duty 2 03-28-2009 05:54 PM
allison 545 automatic trans rustyrelic Whats Been Sold 0 02-09-2008 04:19 PM
Automatic to Manual jjmachine General Ford Truck and Excursion 1 12-02-2007 02:54 PM
Manual automatic? firehillbilly GM Transmissions 3 10-07-2007 12:07 AM
4700 International 2007 Allison automatic thejdman04 Medium and Heavy Duty 14 02-14-2007 11:02 PM
