04 lb7 dtc code - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rjs35510, this thread has received 4 replies and been viewed 1510 times.
post #1 of 5 (permalink) Old 02-09-2010, 02:16 AM Thread Starter
04 lb7 dtc code
I'm trying to find some codes and have managed to find all but 1 it is p1293 does anybody know what it is or where i can find it at thank you.
rjs35510 is offline
post #2 of 5 (permalink) Old 02-09-2010, 03:10 AM Thread Starter
sorry its an 04.5 lly motor if that really matters thanks for any help.
rjs35510 is offline
post #3 of 5 (permalink) Old 02-09-2010, 03:37 AM
TDG Mafia Goon
BombDocDiesel's Avatar
Sounds like it's time for the Ice Pick. I would guess injector 2 or 7 are losing a good connection. Pull the connectors and run a pick or very narrow awl through the plastic and metal spade inside the connector, on the harness. This makes an additional gripping surface to ensure a good connection. Then hook them back up. GM parts direct also sells the longer injector harness to fix this.
Also check near the alternator bracket to make sure you have not rubbed through the harness.
I hope this helps.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #4 of 5 (permalink) Old 02-09-2010, 05:27 AM Thread Starter
the truck threw 10 codes and one was p0207 inj malfunction cylinder 7 so that might be it thanks for the help. but i might need ya later tomorrow cause this is crazy what its doing. i thought it was the harness over the bracket trick but it wasnt acting the same way though.and again thanks.
rjs35510 is offline
post #5 of 5 (permalink) Old 02-09-2010, 11:08 AM
TDG Mafia Goon
My '05 LLY pulled this crap once! It's a pretty easy fix. If you don't like the pick idea I can get you the part number for the harness extension.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
Can I Put J-Code Exhaust Manifolds On a C-Code Engine JLanzino 6.2L Diesel Engine 6 10-08-2009 02:29 AM
P1689 ERROR CODE - Cause of code Found! Mopar1973Man 5.9L Cummins (1998.5-2002) 6 02-02-2009 02:36 PM
STX 500 Code smokinstroke Utility & Farm Tractors 12 04-02-2008 12:50 AM
what does this code mean fender Duramax 2001-2004 (LB7) 7 06-03-2006 05:33 PM
sct and kam code Adam 2003-2007 6.0 Tuner Forum 13 06-02-2006 08:22 PM
