overheating - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rverrcer, this thread has received 5 replies and been viewed 2020 times.
post #1 of 6 (permalink) Old 02-09-2010, 02:53 AM Thread Starter
overheating
Hi all, Im new here and am looking for help to stop my 03 dully from getting hot! I tow heavy and when pulling steep hills she starts creeping up and ofcourse i downshift and do all i can to keep it as cool as posible.
My Question is would mounting a seperate electric cooling fan help? and any advise would be of great help!
rverrcer is offline
post #2 of 6 (permalink) Old 02-10-2010, 01:00 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
the engine is getting hot? Im not sure if you could mount a separate fan anywhere, a Cold air intake, better exhaust, Water injection could be a few places to start.. hard to say, put some info in your Signature so we know what you have done to the truck to begin with, thanks
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 6 (permalink) Old 02-10-2010, 04:27 AM
Gone Fishin...
merlin5577's Avatar
I've pulled quite a bit of weight with my Silverado and never had an overheat problem. Is it actually overheating? Or just getting hot? The LB7 has a huge cooling system, so I would lean towards a component problem VS. needing another fan.
Hows the cooling systems condition? Fan clutch working? Coolant flushed recently? Radiator not blocked by leaves or trash?
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #4 of 6 (permalink) Old 02-10-2010, 03:08 PM
Official TDG Doctor
hccumminssmoke's Avatar
You going by pyro or engine temp gauge in the truck cluster? could be a thermostat..
Nate
hccumminssmoke is offline
post #5 of 6 (permalink) Old 02-15-2010, 03:57 PM
i have had a 97 r3500 cummings and currently have a 2000 r3500 cummings not impressed with either one both are completely stock and when pulling a heavy load say 15000 lbs up a hill they have plenty of power but you cant use it because you have to drive by the temp gauge. i have to drop down to about 40 mph tokeep the temp gauge from climbing to the top the have never over heated but get to close for comfort.i also have a 2003 f650 with a 5.9 cummings it ways 15600 empty i can put a 4door 4wd dually on top and a 32 foot trailer behind it and you cant make it get hot .sure would like to know whats with the other 2 trucks other than the ford has a huge radiator
stotztowing is offline
post #6 of 6 (permalink) Old 02-15-2010, 04:24 PM
CRAZY CANUCK
the larger radiator would probably be the reason, the more cooling capacity the better the cooling, engine heat it derived from combustion heat, intake heat, egts, its a vicious cycle, the hotter the engine gets, the higher underhood temps get, the higher underhood temps get the hotter intake temps get, the hotter intake temps get the hotter the air entering the turbo gets, and hot air being compressed into the engine only gets hotter with combustion, which exhausts into the turbo creating high turbo and EGT's which also feed higher underhood temps.... it spirals out of control, the best thing to do is open the exhaust, open the intake, and make sure your coolant system is in good working order, engine fan clutch, water pump, thermostats, even your radiator, make sure that its not full of gunk, i would even flush the cooling system, and start with fresh coolant, because coolant does break down over time
Ridin Dirty Club #5
TDG TOTQ
overheating bootcamp 2003-2007 6.0L Power Stroke 18 08-04-2009 05:49 PM
F-350 Overheating F350MX 2003-2007 6.0L Power Stroke 16 07-23-2009 10:46 PM
Overheating HorsepowerII 7.3L and 6.9 IDI (Pre 1994) 2 07-14-2007 12:46 AM
Still OVERheating Marvin Medium and Heavy Duty 18 07-08-2007 02:28 AM
LLY Overheating Fix???? gibson2403 LLY Overheating Discussions and Solutions 20 08-22-2006 09:37 PM
