Newb with Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by akbridge, this thread has received 3 replies and been viewed 1022 times.
post #1 of 4 (permalink) Old 03-03-2010, 04:58 PM Thread Starter
Newb with Question
Hey all first time poster here. Lots of good info on the site.
Here is my issue: I have a 2003 GMC 5500 service truck with LB7 engine. The truck has not had an easy life. We got the truck with 90,000 miles on it. At that time we were getting fuel in the oil. So we replace all 8 injectors. This we before GM offered a warranty of sorts. That fixed the problem for a while. Now at 200,000 miles another set of injectors were going bad. We were getting a lot of white and grey smoke in the exhaust and running rough. Injectors were replaced eventually. Three months later the engine went BOOMMM!!!!!! Piston number six decided it wanted to be in thousands of pieces. We licked our wounds found a good running engine out of a 2004 2500 and swapped it in. It ran great for six months. After that time period the engine started getting fuel in the oil. Yay another set!!!! So we swapped in a reman set of injectors. Now things get odd. The truck developed a miss. So we take it to the dealer to get scanned and figure out what cylinder has the miss. It is cylinder #5. The balance rates on all other cylinders are +/-3mm^3, but #5 is +15mm^3. And the duration is .8 ms while all other are .4ms. The dealer wants to sell me a ECM. But I think it is the NEW injector. I have tried an extra FICM. It did not do anything different. I am trying to figure it out. What do you guys think? Is it the injector, ECM, or..... Thanks in advance
Andrew
akbridge is offline
post #2 of 4 (permalink) Old 03-03-2010, 07:59 PM
DrHolliday's Avatar
I would think its the injector... Can't see how the computer would be to blame. Especially since you tried another FICM.
Chris
2006 Chevy 2500HD LBZ/Allison ECSB 4x4 Greystone metallic
S475, 3" boost tubes, 5" intake, Custom Y-Bridge
Tuning and Transmission by Diesel Addiction . A special thanks to Dustin for all the help.
12.42 @ 106.3 (stock injectors, CP3, and turbo, no drugs!)
7.83 @ 86.2 1/8th
531 RWHP / 940 RWTQ 10/11/08 on Wayne's Dyno in Jville NC
USMC 2002-present
DrHolliday is offline
post #3 of 4 (permalink) Old 03-07-2010, 04:58 PM
Toyaholic
Injector. He just showed you the balance rate is off himself. Maybe that tech should stick with Colbolts.
01 Chevy CC/SB 4WD. Not Quite Stock.
vrabel is offline
post #4 of 4 (permalink) Old 03-12-2010, 01:36 PM
Cummins Tower
Cwalt's Avatar
i say injector
-Cliff
"You know you wanna win the round, So when that brindle comes around, You better cok your hammer down, Don't quit till you head hits the ground, Go on and lift that leg and spur
You gotta get up in the neck, Step off and pick up your check" - Colby Yates
06 chevy silverado 2500hd duramax work done by dieseljunk.com!!
02 gmc sierra 2500hd duramax. if you only knew work done by dieseljunk.com!!
09 appalachian 24ft gooseneck trailer
Cwalt is offline
Newb question about LB7 Vs. LLY rickou812 Duramax 2001-2004 (LB7) 2 05-03-2009 02:52 PM
Here comes another NewB PGreenSVT Introductions 9 04-08-2008 02:58 AM
Question from a newb! blueballin 1994-2003 7.3L Power Stroke 10 10-20-2007 02:21 PM
Newb question Herrick General Diesel 2 06-12-2007 11:05 PM
Newb 24V Introductions 7 05-01-2007 07:27 PM
