Advice on purchasing a 2003 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ladder06, this thread has received 4 replies and been viewed 1186 times.
post #1 of 5 (permalink) Old 05-02-2010, 07:19 PM Thread Starter
I am looking to get out of my Ford and into a 2003 K2500 (82,000 miles) with the Duramax engine. The dealer is asking $22,900. Crew cab with the works. Can someone give me advice on what to look for? I had the 6L Ford diesel and am sick of blown head gaskets and the $5K price tag to fix them.
Are there similar problems with the chevy diesels? Any common problems...ie. injectors, head gaskets,etc? How do I check that?
Thanks everyone!
ladder06 is offline
post #2 of 5 (permalink) Old 05-03-2010, 02:37 AM
Pardue the Traveler
New 0mega's Avatar
You only blow head gaskets on a Duramax if its making big boost. The only thing to check on the '01-'04 LB7 is if/when the injectors have been replaced.
check out this page for any other questions https://www.thedieselgarage.com/forum...ad.php?t=92868
Singles Club member #250
New 0mega is offline
The Following User Says Thank You to New 0mega For this addition to TDG:
ladder06 (05-19-2010)
post #3 of 5 (permalink) Old 05-06-2010, 12:45 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
The Duramax uses 6 headbolts per cylinders as opposed to the 4 headbolts per cylinder on the 6.0L powerstroke
The LB7's can be pretty good motors as long as the injectors are good, i would run a VIN check here> https://www.thedieselgarage.com/forum...play.php?f=100 but it appears that RIPMF666 hasnt been keeping up with them, you can also post it on this page http://www.dieselplace.com/forum/forumdisplay.php?f=72 Its a different forum that you will have to join but they usually take a day or two to return your vinchecks, its very valuable to know what kind of warranty work has been done to your truck before you buy it
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #4 of 5 (permalink) Old 05-14-2010, 04:04 AM
03 04 lb7s are great trucks, parts are little cheaper the injectors are larger and flow better just make sure they have been changed to the second gen injectors, the 1st gen 1s stick the lb7 has more compression and less turbo,just replace the headstuds 1 at a time with head studs and boost away,i was running 35 lbs of boost for 3 years and the gasket finaly poped at 165,000.bought another motor with only 2000 miles on it for $2000
blk smoke lb7 is offline
post #5 of 5 (permalink) Old 05-14-2010, 04:09 AM
1 more thing make sure any 03 04 your looking at DOESNT have a cat or an egr valve i have 2 buds that bought cali models and they both have check engine lites due to egr valves,the 49 staters dont have cats or egr valves.you will be very happy with it
The Following User Says Thank You to blk smoke lb7 For this addition to TDG:
purchasing II 62/70 strokin6L 2003-2007 6.0L Power Stroke 73 04-13-2009 12:09 AM
Purchasing a used 7.3 powerstroke2003 1994-2003 7.3L Power Stroke 2 08-08-2007 04:09 AM
TST advice for 2003 ash_flat_diesel 5.9L Cummins (2003-2007.5) 3 06-30-2007 11:24 PM
Laptop purchasing advice hoot The Parking Lot 9 05-22-2007 11:41 PM
Need help purchasing new rig I10HaulR Medium and Heavy Duty 20 02-06-2006 04:39 AM
