need some help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by AmarilloSD, this thread has received 2 replies and been viewed 1464 times.
post #1 of 3 (permalink) Old 05-13-2010, 05:55 PM Thread Starter
AmarilloSD's Avatar
need some help
well the feared coolant leak on my buddies 01 duramax is coming out of the headgaskets, ive been tearing down to get to them and am in the process of removing the turbo, i have the down pipe off what a pain in the A** now need to get the up pipes off, anyone have any tricks up their sleeves or a tool or two i could pick up to make the job easier?
2006 f350 C.C.SB Amarillo Edition- Afe Stage 2 intake, SCT, mbrp 5" turbo back with 6" tip, 7" icon lift,325/50/22 dynapro atms on 22x11 black XD diesels, keystone heat extractor hood, 4.30 gears, 03 turbo DR/icon traction bars, Hd Heads, Painted front and rear bumpers, arp head studs, Welded EGR
wish list/coming soon-banks ic, regulated return fuel system, Tuned FICM, but not if i do a CR cummins first!
AmarilloSD is offline
post #2 of 3 (permalink) Old 05-14-2010, 03:38 AM
try flex head ratchets,i blew a head gasket and found another motor to just drop in.be careful when you get the gaskets there are 3 different thicknesses of gaskets for lb7 to be safe just get the thickest 1s to be safe especialy if you have to mill the head at all,dont forget the arp head studs
blk smoke lb7 is offline
post #3 of 3 (permalink) Old 05-14-2010, 03:46 AM
also if you take the bolts out of the back of the manifold on both sideyou should be able the pull the turbo with both uppipes still bolted to the back of the turbo i think,when i did mine the motor was out.
