performance issues - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by chime1ssi, this thread has received 3 replies and been viewed 1074 times.
post #1 of 4 (permalink) Old 05-16-2010, 12:50 PM Thread Starter
performance issues
Having an issue with my '03 when I hammer down on it on the fly (usually between 35-50 mph) it starts to act like it is flooding and won't go over the rpm's it ramped up until I let up the accelarater and ease back into it to get up to speed. I have airaid air intake, Edge Juice w/ monitor, 4"MRBP turbo back. When I put it on stock it doesn't do it as frequently however it is doing it regularly on level 3 . Any clues?
chime1ssi is offline
post #2 of 4 (permalink) Old 05-17-2010, 08:51 AM
Pardue the Traveler
New 0mega's Avatar
Sounds like the transmission is limiting power due to clutch slippage.
Singles Club member #250
New 0mega is offline
post #3 of 4 (permalink) Old 05-17-2010, 03:58 PM
fuel filter getting clogged would be my guess, or the mass airflow sensor getting dirty/oily, I would lean towards either as they are rather simple to check both. Hope that helps.
03 Chevy Silverado 2500 HD, K/N intake, PPE boost fooler, Edge hot juice w/monitor, 4" MBRP turbo back exhaust, Line X bed lining, B/W turnover hitch, Merchant Automotive xfer case pump upgrade
Dux2bux is offline
post #4 of 4 (permalink) Old 05-19-2010, 04:12 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
The edge module may be defueling due to excess EGT's, Boost, or transmission slippage, check your edge manual to see how you can change those defuel points
If the engine revs up then its a transmission flare because the allison hasn't learned to deal with the extra power that you adding with the Edge, allow the transmission to learn a new tune well before abusing it
And like Dux2Bux said change your fuel filter and check your MAF sensor
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
Dr. Performance Predator Performance Module for '04.5-'07 yfz450_0569 Whats Been Sold 1 11-03-2009 08:19 PM
New edge juice ,some performance issues and ?s MILKINGCOWBOY 5.9L Cummins (1998.5-2002) 9 08-14-2009 10:13 PM
Performance issues?? New Guy 1994-2003 7.3L Power Stroke 24 12-17-2007 06:56 AM
Performance issues?? New Guy Introductions 2 12-02-2007 10:41 AM
DT466e start/performance issues darlington Medium and Heavy Duty 25 09-11-2007 02:22 AM
