speed limiter - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by chime1ssi, this thread has received 7 replies and been viewed 2150 times.
post #1 of 8 (permalink) Old 05-16-2010, 01:54 PM Thread Starter
speed limiter
Does anyone know how to eliminate the speed limiter on 03 dirtymax. have juice w/ attitude and nothing.
chime1ssi is offline
post #2 of 8 (permalink) Old 05-16-2010, 05:55 PM
Gone Fishin...
merlin5577's Avatar
Most hand held programmers will let you change the top speed. Are you talking about the factory preset 96MPH or dealer installed 70MPH?
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #3 of 8 (permalink) Old 05-16-2010, 06:06 PM
find an old superchips for the 01 to 03 d max and you can just loadwhatever you need out of it.that will also let you recalc for larger tires also and WHEN you get a big trans if you dont already you can stack the super chips with the edge if you want
blk smoke lb7 is offline
post #4 of 8 (permalink) Old 05-16-2010, 08:52 PM Thread Starter
thank you noone i have talked to had a clue. we thought the edge would do the trick.... i was refering to factory 96 mph
post #5 of 8 (permalink) Old 05-17-2010, 12:35 AM
you can pick up 1 of those super chips max micro tuners for around 60 to 100 and it will add 90 horse to your computer but you have to back the edge off your trans if its stock wont handle all that power.you will notice the computor load reacts faster
post #6 of 8 (permalink) Old 05-19-2010, 05:05 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
I dont recommend stacking tuners and programmers on these engines,you will get too much injection timing and can crack injectors or cook pistons.... they can create some intense heat as well, its just not a great idea.... either run one or the other, not both, or sell the edge and pick up a PPE xcellerator, it will do a lot more for you than stacking
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #7 of 8 (permalink) Old 05-20-2010, 03:50 AM
im running the ppe hot+2 eliminator on setting 8 and the edge hot juice on 2 with not problems but i am going to take some of the timing out
post #8 of 8 (permalink) Old 06-27-2010, 03:03 AM
Toyaholic
EFI Live can eliminate
01 Chevy CC/SB 4WD. Not Quite Stock.
vrabel is offline
Cheapest Speed Limiter Removal? dieselram55 2003-2007 6.0L Power Stroke 5 12-26-2007 11:38 PM
speed limiter imported_fisher250 Duramax 2006-2007(LBZ & LLY) 2 10-30-2007 02:55 AM
Speed limiter Snowaholic 5.9L Cummins (2003-2007.5) 14 05-15-2007 05:44 PM
Tuner & Speed Limiter Removal Matty69 LBZ & LLY Tuner Forum 4 01-24-2007 04:24 AM
Speed De-Limiter maxxis_mudder Duramax 2004.5-2005(LLY) 11 02-27-2006 04:53 PM
