coolent probs. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by big peter, this thread has received 15 replies and been viewed 2062 times.
post #1 of 16 (permalink) Old 12-24-2007, 02:36 PM Thread Starter
member
Thumbs down coolent probs.
hey all just installed my new 4" exhaust (made my-self), now i am having trouble with it getting hot, i can be going down the road at 55 mph and 1800 rpm and have normal temps.(around 190) then i go 1 mile at the same speed/rpm and the temp. will jump to 220, go another mile and back to 190/ 200....If drive more aggressive and get on it , it runs cool but when i back off the temp gauge will shoot up then go down in a min or two.
correct me if im wrong but I know the exhaust probly is not makeing it do this but mabee the thermostat? or fan clutch?
please help!!!:HITFAN:
"Don't aproch a horse from the front, bull from the rear, or a FOOL from any direction" :deadhorse
-94 chevy 2500 6.5 diesel,4x4, hypertech chip, 40 hp injectors, new inector pump, 4" exhaust 3"down pipe, #9 resestor, ported and polished heads and intake, eagle allows
-1993 E-350 (service truck) 7.3 idi 80,000
-1997 f-350(farm truck) single wheel, 4x4, 7.3,custom exhaust coming soon
- 2005 f-150,4x4, sct tuner
big peter is offline
post #2 of 16 (permalink) Old 01-31-2009, 01:58 AM
Check the T-stat and coolant level.
I would also check the grounds.
95% of my electrical calls @ work are bad grounds.
TECHLINETOM is offline
post #3 of 16 (permalink) Old 01-31-2009, 11:40 PM
chrisk1500's Avatar
Most likely T-stat...
You may want to pull the rad out of the truck and give it a solid pressure washing to clean all of the leaves and grit out of the fins....
07.5 LMM DMAX, 2500 HD, LT, PCV re-route, resonator delete, Edge EVO/RACE - level 3 --> coming soon: lift pump, MBRP 4", Trans Go Jr.
14.1 @96.2 MPH
84 Chev 1500, 6.2, auto
chrisk1500 is offline
post #4 of 16 (permalink) Old 02-01-2009, 04:52 PM
TDG capo dei capi
Phantom 309's Avatar
head gasket starting to leak,.
Phantom 309 is offline
post #5 of 16 (permalink) Old 02-01-2009, 10:24 PM
I do not recommend pressure washing a radiator!!
BAD IDEA!!
What will happen is the tiny little fins will get bent over and the rad will be JUNK!
However running a garden hose ( no nozzle) over it from the backside (maybe with some detergent from a sprayer or gunk engine cleaner) will work wonders for removing garbage from between the fins.
Last edited by TECHLINETOM; 02-01-2009 at 10:25 PM. Reason: can't type worth a @#%^%$!
post #6 of 16 (permalink) Old 02-01-2009, 11:53 PM
chrisk1500's Avatar
BAD IDEA!!
Well you don't use a 0* nozzle!
A good pressure washing with a wide nozzle is what I use on these, and all other rads I clean out in our fleet....don't spray at an angle and you won't bend any fins....
14.1 @96.2 MPH
post #7 of 16 (permalink) Old 02-02-2009, 08:11 PM
M123KT-450's Avatar
That seems a bit Hot Mine Floats between 175*F n 185*F depending on how hard its getting pushed Load Very heavy drive hard with OD off it may get as hot as 190 never seen it hit 200+. . .
I would check out the T-state and the Coolant levels the lower Radaitor hoses on them things leak, Right in that plastic oart where the Snaller hose splits off the had to the Oer flow/Radaitor Cap. . .:Took me a while to find the leak as it would never leave nothing on the ground but every 1500-1700 miles it would throw a low coolant light. . .I have the hose i'll be fixing mine this spring. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #8 of 16 (permalink) Old 02-03-2009, 05:58 AM
SneakyPete's Avatar
I just fixed a 6.5 for a friend that was constantly doing the same thing. The kit from SSdiesel is a nice one with the duramax fan dual t-stats and higher flow water pump you'll never come close to getting hot again... Unless you have a head problem such as cracked heads or blown head gaskets but to check for that you can pressure test your cooling system or let your truck get up to temp and with the coolant fill cap off see if you have bubbles in your resivior or if you have excess pressure if you hold your hand over the cap hole and remove it.
Singles club #167
99 F250 2wd to 4wd conversion, Stealth stage 2 Hpop, 1.15 AR housing with van flange, early 99 intake wheel, Air dog II 130/75, Regulated fuel return, Diy stage 2 single shots, Dpp custom tunes, Afe intake 4" downpipe, rear 12 leafs(unbelievably rough), hancook rto3's on teflon baha's, Black headlights, taillights and stacks,... Lots of trans work.
99 (early 99) F350 7.3l CC long bed srw 4x4, Stock....For now.
89 1500 Blazer 6.2L 2" lift, 6.5L Turbo, 94 6.5L serpentine belt assembly, Western plow and spreader.
SneakyPete is offline
post #9 of 16 (permalink) Old 02-06-2009, 08:16 PM
acesneights1's Avatar
You have no sig but under your username it says 94 so I'll assume you have a 94. 94=single thermostat. replace it witth factory gm from stealer rape 40$. Do not use autoparts one. GM AC/Delco only.. If it has an aftermarket one in it that is most lileky your problem. Start there.
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP. Serp belt conversion. 5 inch redneck master exhaust. DB2831 IP. Dmax fan. Humvee waterpump.
1981 AM General M35A2c
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline
post #10 of 16 (permalink) Old 02-09-2009, 01:26 AM
I generally use a Robertshaw 330 series.
Also sold by Mr Gasket, Milodon, Stewart, and Brassworks (Flowcooler).
These are pressure balanced and high flow too.
P.S. No offence Chris but I'm VERY careful of what I tell people( can't make any assumptions as to their mechanical aptitude). It can get ugly quick.
