4L80E - SURPRISE! No Reverse! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rossww, this thread has received 3 replies and been viewed 3846 times.
post #1 of 4 (permalink) Old 09-26-2010, 01:44 AM Thread Starter
95 Silverado 6.5 TD
I've got a 6.5 turbo diesel, type "s"; Ext cab; 2wD.
Got in one morning and no reverse.
Fluid was burnt.
Changed fluid, filter and seal -still no reverse -nothing at all!
All other gears work perfectly.
I'm told the reverse band is fried, I'm hoping someone gives me a much cheaper solution.
If it is dead and I need to get a used one, I'm told by the local dealership that ONLY trannys from this list (no exceptions) will fit in my truck:
-2WD
-Chev/GMC
-1500/2500
-1995
-Ext. Cab
-6.5 Diesel (maybe a different sized diesel, I'm not certain on that)
From what I understand, it can't come from a suburban, van, or anything other than from above list.
Can someone confirm this for me?
Also, I know this is wishful thinking, is there anything in the steering wheel/column that electronically controls reverse. There's something loose, sounds like it's coming from the steering wheel itself, that's rolling around and klunking everytime I turn the wheel.
rossww is offline
post #2 of 4 (permalink) Old 02-22-2013, 02:26 AM
Thumbs up
If the reverse band is toast pull the transmission and have an ATRA certified shop rebuild it unfortunately youre looking at a couple grand.
If youre using it for work or drive it hard and plan to keep it spend the extra couple hundred for the level 2 upgrades and tuning the TCM and ECM computers. A proper tuning will sink up the computers to get the most out of the trans and help it run cooler. If its a daily driver the tuning is still worth the money but a shop must do it.
Bob Wolf
BobWolf is offline
post #3 of 4 (permalink) Old 02-22-2013, 02:01 PM Thread Starter
95 Silverado 6.5 TD
Hey Bob!
Thanks for the info! Unfortunately, if you look at the date I posted, you'll see that it was in 2010.
Ended up changing the tranny to a heavy duty one. Shortly after that, the engine blew a head gasket.
I really miss that truck!
rossww is offline
post #4 of 4 (permalink) Old 02-23-2013, 05:20 AM
My bad.
Bob Wolf.
BobWolf is offline
95' 4L80E only got 2nd & Reverse M123KT-450 GM Transmissions 18 02-15-2010 05:22 AM
Surprise..... Morpheus cycles The Parking Lot 12 05-23-2007 02:31 AM
What A Surprise BROKER The Parking Lot 3 06-07-2006 03:49 PM
