83 6.2 700r4 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fellro86, this thread has received 2 replies and been viewed 1196 times.
post #1 of 3 (permalink) Old 08-08-2007, 04:34 AM Thread Starter
83 6.2 700r4
Ok, here's the story. No overdrive, been used for towing. Can't answer yet on the trans condition by looking at the oil pan deposits. I had thought a gas trans and the diesel trans should interchange, it would appear I am wrong about that, as the diesel converter won't fit the gas trans, as well as the fact the diesel converter has 6 bolts vs. the 3 on the gas. Thoughts on what is going on?
The workhorse: 86 F250 6.9 4 speed 4wd 4.10 gears, electric fuel pump
The other workhorse: 92 F350 2wd crew cab, 92 6BT Cummins, NV4500 and GV overdrive unit, 4.10 rear axle
fellro86 is offline
post #2 of 3 (permalink) Old 08-10-2007, 05:00 PM
gas vs diesel transmission....
That's discouraging news, as I was hoping to drop a 6.2 and a new torque converter into a gas suburban.....
If what you say is true, I'll have to swap out the whole drivetrain to do a gas to diesel conversion? In the General's neverending quest to improve the bottom line, I'd be surprised if they made different casings for gas or diesel 700R4s....
wasco is offline
post #3 of 3 (permalink) Old 08-10-2007, 07:47 PM Thread Starter
Well, this is an interesting discovery... the gas trans has a LARGER input shaft... Must be the gas trans is newer than the diesel, which from looking at the motor would stand to reason, it is at least a 90 or so gas motor, and the trans may well be originally from 83...
fellro86 is offline
Closed Thread
