transmission wont shift! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cowboyupp16, this thread has received 3 replies and been viewed 1441 times.
post #1 of 4 (permalink) Old 01-07-2008, 10:19 PM Thread Starter
hey yall ive got an 02 3500 4x4 with allison, i noticed a few nights ago that when im at full throttle and the tranny is changing from 2nd to 3rd and 3rd to 4th it sticks and i have to back off the gas for it to change,has anyone else had this problem? and know wuts it is?
cowboyupp16 is offline
post #2 of 4 (permalink) Old 01-08-2008, 11:47 AM
SRW Cartell #27
Stacked6600's Avatar
How long has it been since you changed your spin on Trans filter? You may need to put a clean one on.
1999.5 F250 4x4 super cab 7.3L With edge attituede.
Converter lockup mod and EBPV exaust brake mod.
Air Hog cold air intake. Muffler delete, 35s on centerlines.
New F650 dash upgrade..
1995 F250 Single cab long bed 2wd.
2001 LB7 2500HD SOLD
AEM Brute Force intake, 5 1/2 stack exaust, Diablo Sport Predator Programmer. PPE boost valve, Autolite gauges. Built Allison (Alto steels, Red eagle clutches, Transgo shift kit, transgo lockup valve, and Personal Mods : ) edelbrock 1792 lift pump.
Singles Club Member #27
Stacked6600 is offline
post #3 of 4 (permalink) Old 02-03-2008, 03:05 PM
Afrye
Yea check the filter, has your tranny ever been flushed, there is another filter in the pan, also check the tranny fluid i had the same problem and had a fitting leaking slowly and was just low on fluid. No fluid = no line pressure = no shift
02 4-Door Dually Duramax, Eagle Alloy Wheels, Western Diesel Boost & Pyro Gauges,BD Dual Exhaust, BD Cold Air Intake, Juice with Attitude, Hot unlock, PPE boost vavle, soon to have BD full bore manifold,and eventually a tranny!
lb7man08 is offline
post #4 of 4 (permalink) Old 02-03-2008, 03:17 PM
Are you running a programmer?
TheBac is offline
