6.5-T oil cooler turned into 4L80E cooler ! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by M123KT-450, this thread has received 8 replies and been viewed 2072 times.
post #1 of 9 (permalink) Old 08-22-2009, 08:15 PM Thread Starter
M123KT-450's Avatar
I have finally gotten my cooler upgrade done
All went very well mounts right in with a brass adaptor everything hooks up perfectly
After idling and half hour drive trans fluid lines still cool enough to touch
worked out well and costs all of $45 to do and takes 1 hour with fluid n filter change HD COOLER
Mike
PHOTOS:
Name:	cooler upgrade 1.jpg
ID:	21349   Click image for larger version
Name:	cooler upgrade 2.jpg
ID:	21350   Click image for larger version
Name:	cooler upgrade 3.jpg
ID:	21351   Click image for larger version
Name:	cooler upgrade 4.jpg
ID:	21352   Click image for larger version
Name:	cooler upgrade 5.jpg
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #2 of 9 (permalink) Old 08-24-2009, 11:23 PM Thread Starter
M123KT-450's Avatar
Now after a few days of driving it transmission seems to shift a bit firmer and is more responsive.
So i'm going to have say this project was a successful Upgrade
load it Heavy & Run it Hard
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #3 of 9 (permalink) Old 08-26-2009, 12:10 AM Thread Starter
M123KT-450's Avatar
after driving to work i parked my truck as normal about 10-20min after parking i desided to touch my cooling line the trans cooler was luke warm at best ! and my engine oil cooler was still flipping Hot ! I think them OEM oil coolers cool the transmission way better then they cool the engine oil. . .May have to find an engine oil cooler upgrade no room to go bigger maybe get the large cooler with the fan ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #4 of 9 (permalink) Old 08-26-2009, 01:42 AM
Gone Fishin...
merlin5577's Avatar
Looking good Mike. Job well done!
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
The Following User Says Thank You to merlin5577 For this addition to TDG:
M123KT-450 (08-26-2009)
post #5 of 9 (permalink) Old 08-28-2009, 12:02 AM Thread Starter
M123KT-450's Avatar
My transmission may just out live the engine . . .
Tho for me that would be a GM normality . . .
For me:
1. GM has the weak engines. blow up or wear out. Continuous Alt failures
2. Ford has the weak transmissions n rear ends. auto trans failures or rear end strips yoke intermittent alt failures .
3. Dodge has the weak chassie/suspension n electrical systems. Tho i haven't had 1 alternator failure plenty of Ignition failures tho
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #6 of 9 (permalink) Old 08-28-2009, 05:30 PM
Pardue the Traveler
New 0mega's Avatar
The Duramax is a good motor, so that throws a monkey wrench into your statement about gm's.
Singles Club member #250
New 0mega is offline
post #7 of 9 (permalink) Old 08-28-2009, 09:58 PM Thread Starter
M123KT-450's Avatar
The only 2 GM engines i have had issues with is the 350SB (blew up 7 of them) and the 6.5 Turbo Diesel ( repeated brake downs lack of power) .
Tho i did have 2.5L I-4 fail on me but it had 215K miles on it . . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #8 of 9 (permalink) Old 08-30-2009, 11:53 PM
Pardue the Traveler
New 0mega's Avatar
my dad took two 350 tbi's out in his last truck, two transmissions and a rear end as well.
post #9 of 9 (permalink) Old 09-03-2009, 03:34 AM Thread Starter
M123KT-450's Avatar
Normally a 350 chevy don't last me but 1 summer.
Mid fall it'll spin bearings and stab a whole in the block and oil pan with bits n pieces of the rotating assembly, the lower end's just don't seem to hold up well. . .
I'm not really a fan of the 350 chevy the 302 ford or the 318 dodge, i have had routine and repeated failures with all 3 of them. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
Adapting oil cooler to trans cooler 4L80E. . . M123KT-450 GM Transmissions 16 08-15-2009 10:44 PM
New oil cooler and EGR cooler delete Spindrift 2003-2007 6.0L Power Stroke 18 07-09-2009 12:50 AM
Brand New Oil Cooler & Egr Cooler For 6.0 760 PSD Whats Been Sold 2 03-17-2008 02:07 AM
Would Banks Techni-cooler Help Save The Egr Cooler From Failing? nemotorcars 2003-2007 6.0L Power Stroke 9 01-01-2008 08:42 PM
Egr Cooler blowin smoke 2003-2007 6.0L Power Stroke 23 01-31-2006 04:14 AM
