95' 4L80E only got 2nd & Reverse - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by M123KT-450, this thread has received 18 replies and been viewed 10553 times.
post #1 of 19 (permalink) Old 12-15-2009, 06:56 PM Thread Starter
M123KT-450's Avatar
I went to the store and i had all 4 gears coming back from the store i lost 4th n 3rd 1st . . .
Any thoughts ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #2 of 19 (permalink) Old 12-15-2009, 10:28 PM
SSpeeDEMONSS's Avatar
broke a shaft? nut came off?
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 19 (permalink) Old 12-15-2009, 10:29 PM
oh yeah, its an auto. maybe something electronic?
post #4 of 19 (permalink) Old 12-15-2009, 10:52 PM Thread Starter
M123KT-450's Avatar
I can manually shift it into all 4 gear selections but the transmission itself doesn't respond, it starts out in second gear and dose not shift, unless put into reverse.
I have 2nd gear and reverse neutral and park . . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #5 of 19 (permalink) Old 12-16-2009, 02:21 AM
********* and Mafia #90
Bcarriveau's Avatar
Automatic Transmission/Transaxle: Testing and Inspection
Diagnosis By Symptom
Converter Ballooning
Converter limit valve stuck open due to sediment or undersized bore
Delayed 1-2 Shift
1. Electrical malfunction or incorrect air gap of output speed sensor.
2. Input speed sensor electrical malfunction.
3. Pressure switch manifold electrical malfunction.
4. PROM calibration incorrect.
5. Digital ratio adapter malfunctioning.
Engine Stalls
1. Forward clutch housing bearing seized.
2. Fourth clutch plates, piston or spring assembly seized or jammed.
3. Torque converter clutch (TCC) stuck or dragging.
Engine Starts In Gear
1. Manual valve not engaged to detent lever.
2. Neutral safety switch malfunctioning.
Fluid Foaming
1. Fluid contaminated or overfilled.
2. Engine overheated.
3. Filter cracked or not seated.
4. Seal damaged or not seated.
5. Vehicle overloaded.
Forward Motion In Neutral
1. Manual valve stuck.
2. Forward clutch springs, piston, and plates jammed.
3. Forward clutch housing and hub hole(s) plugged.
Hard to Shift Out of or Remains In Park
1. Weak or broken pawl return spring.
2. Actuator rod assembly stretched.
Harsh Shifts
1. Line pressure to high or low.
2. Force motor malfunctioning.
3. Loose PCM connector.
4. Accumulator piston or spring incorrect or missing.
5. PROM calibration incorrect.
Improper TCC Application or Release
1. Speed sensor:
a. Poor connection.
b. Pinched wire.
c. Coil wire broken.
d. Incorrect air gap.
e. Inadequate signal.
2. Throttle position sensor and engine coolant temperature sensor
malfunctioning due to poor connection, pinched wire, no signal to PCM or incorrect
resistance.
3. PCM Failure.
4. Brake switch malfunctioning due to poor connection, no signal to PCM or pinched wire.
Inaccurate Shift Points
1. Electrical malfunction or damaged rotor teeth of output speed sensor.
2. Electrical malfunction of throttle position sensor or pressure switch manifold.
3. Incorrect or non original axle ratio or tire size.
4. Digital ratio adapter malfunctioning.
Insufficient Lube
1. Pressure regulator valve stuck in high demand position.
2. Cross dressing leakage in pump body.
3. Pan gasket leaking.
4. Leaking oil transfer hole cup plug.
Insufficient Lube at Low Line or Under Heavy Load
1. Converter limit valve dirty.
2. Retainer pin broken.
Loss of Drive
1. Faulty torque converter.
2. Seized or broken pump.
3. Case extension seal missing, damaged or displaced.
4. Orifice plate missing or leaking around edge.
5. Oil transfer hole cup plug leaking or missing.
6. Broken or excessively worn clutches. bearings, pinions, gears or shafts.
Loss of Power
1. Low transmission oil.
2. Vehicle not initially accelerating in first gear.
3. Torque converter clutch (TCC) stuck dirty, or dragging.
4. Stator shaft broken.
5. Turbine, main or output shaft bushing worn.
Low Line Pressure
1. Cross channel air leak body to cover or body to case gasket at pump.
2. Pressure regulator valve stuck or reverse boost valve at low torque signal due to dirty or undersized bore.
3. Excessive valve clearance in pump valve bores due to use.
4. Cross channel leaks or cross valve land leaks at valve body.
5. Gaskets/spacer plate damaged or missing.
6. Force motor stuck on, broken clip causing leakage, pinched wire to ground or screen missing.
7. PCM module failure.
No First Gear
1. Housing broken.
2. Rear band anchor pin broken or not positioned.
3. Detent lever misaligned.
4. Front band stuck on.
5. Low roller assembly not attached or race broken.
6. Case damaged near center support.
7. Snap rings not seated.
No Fourth Gear
1. 2-3 shift valve stuck.
2. Solenoid B malfunctioning.
3. Quad driver module failure.
4. Overrun clutch reaction plates splines.
5. Fourth clutch components:
a. Cup plug or bolt loose, broken or missing.
b. Piston or spring assembly jammed.
c. Seals nicked or cut.
d. Friction or reaction plates worn or burned.
No Gear Selections
1. Detent lever nut loose or missing.
2. Manual valve stuck.
3. Spacer plate holes blocked.
4. Blocked channels at valve body case.
No Park
1. Incomplete travel or misaligned detent lever.
2. Disconnected or broke actuator rod.
3. Detent spring mispositioned.
4. Parking pawl, bracket or shaft broken.
5. Front internal gear splines broken.
6. Manual shaft flats not parallel.
No Reverse
1. Transmission mountings or seals broken or leaking.
2. Rear band broken or worn.
3. Rear band apply pin or piston to short or binding in case.
4. Low fluid pressure.
5. Direct clutch components worn, jammed, cracked or leaking.
No Second Gear
1. Front band anchor pin broken or mispositioned.
2. Intermediate clutch feed cup plug missing or not seated.
3. Intermediate clutch components:
a. Broken backing plate.
b. Snap ring missing or not seated.
c. Friction plates or outer race splines worn.
d. Center support bolt broken, loose or oil hole blocked.
e. Seals, piston or springs worn cracked or jammed.
f. Intermediate sprag worn or broken.
4. Direct clutch housing broken.
No Third Gear
4. Intermediate clutch components:
a. Leaking ball check, seals or center support.
b. Reaction and friction plates splines worn.
c. Spring assembly jammed.
d. Housing cracked.
No Torque Converter Clutch (TCC)
1. TCC system:
a. Stuck off.
b. O-ring failure.
c. No voltage to solenoid.
d. Poor electrical connection.
2. Brake switch:
a. Contact corroded.
b. Poor electrical connection.
c. Pinched wire.
d. Misadjusted.
e. No supply voltage.
3. Solenoid malfunctioning.
4. Quad driver module failure.
5. TCC valve stuck due to debris or undersized bore.
6. Retainer pin broken.
7. Ballooning torque converter.
8. Turbine shaft plugged oil holes.
9. Turbine shaft seals or pump body bushings worn out.
10. Oil transfer hole cup plug leaking.
11. Regulated apply valve stuck.
12. TCC valve release exhaust orificed cup plug blocked.
No Torque In Reverse & Third
1. Forward clutch hub broken.
2. Forward clutch housing.
No Torque In Second Gear
Intermediate sprag broken or worn.
No Torque Multiplication
Stator shaft is broken or detached from pump cover.
Noise/Vibration
1. Torque converter either has loose lug bolts, is out of balance or has internal failure.
2. Transmission and engine assembly misaligned.
3. Case extension output shaft support bushing worn.
4. Turbine, main or output shafts have worn bushings.
5. Bearing is worn.
Oil Pressure High or Low
1. Pressure regulator valve or reverse boost valve stuck at high torque signal because of debris or undersized bore.
2. Retainer plug broken.
3. Orificed plug blocked.
4. Loose connector on PCM, force motor or pressure control solenoid.
Second Gear Starts
1. Intermediate clutch plates seized.
2. Direct clutch lube feed blocked.
3. Center support springs or pistons jammed.
4. Incorrect PCM signal to solenoid.
5. Quad driver failure.
6. 1-2 shift valve stuck.
7. Solenoid failure due to being stuck off, O-ring failure, no voltage to solenoid or poor connection.
Shift Lever Indicates Wrong Gear
1. Detent pin misaligned or broken.
2. Manual shaft flats not parallel.
3. Indicator linkage misadjusted.
Slipping TCC
1. TCC valve release or exhaust orificed cup plug blocked.
2. Turbine shaft seal cut.
Slow Application of TCC
1. Turbine shaft seals or pump body bushing worn or ineffective.
2. O-ring heat set.
3. Oil transfer hole cup plug leaking.
4. TCC solenoid malfunctioning.
5. Low fluid pressure.
TCC Stuck on
1. Malfunctioning TCC solenoid.
2. TCC apply valve stuck.
Third Gear Starts
1. Forward clutch driving hub hole plugged or plate seized.
2. Direct clutch plate seized, piston or spring assembly jammed or lube feed hole blocked.
Transmission Overheats
1. Blockage in apply or release in TCC circuit.
2. TCC valve spring broken.
3. Cross channel leakage in pump cover.
4. Blocked oil cooler or lines.
5. Retainer pin broken.
6. Turbine shaft O-ring, seals or stator shaft damaged or worn.
7. Leaking oil transfer hole cup plug.
8. Low transmission fluid level.
9. Restricted air flow to radiator.
10. Converter limit valve bypass orificed cup plug blocked and converter limit valve stuck closed.
100K miles on 4/7/2010
2005 F250 FX4 Supercab Shortbed
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #6 of 19 (permalink) Old 12-16-2009, 04:47 AM Thread Starter
M123KT-450's Avatar
Second Gear Starts
This is the symptoms W T H how dose one check these 7 above things ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #7 of 19 (permalink) Old 12-17-2009, 01:44 PM Thread Starter
M123KT-450's Avatar
ok as for #4 n #7 how do i go about testing them ?
I can see if there is power which will solve #7 if i knew where to test. . .
#4 incorrect signal, well with out knowing what the signal's should be how do i test that ? is it X-volt ? or is it X-ohms ? X-pulsation rate ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #8 of 19 (permalink) Old 12-17-2009, 09:23 PM Thread Starter
M123KT-450's Avatar
charged up my dead batteries it finally fired right up, i let it run for about a half hour then i drove it around for an hour and it shifted threw all 4 gears perfectly.
W T H
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #9 of 19 (permalink) Old 12-18-2009, 04:51 PM Thread Starter
M123KT-450's Avatar
Ok it strikes again, 2 & R is all i have again.
So i was on my way to parts house to get the Master cylinder for the jeep, and all was well truck ran great and drove fine.
apon leaving the parts house to get out into traffic i punched it down it down shifted rapt threw gears 1 . . 2 . . . 3 . i let off it hit 4th . . . then the SES light came on as it dropped back into 2nd gear where it stayed.
So i continued to drive to the bank and then drove back on home, just before getting home i pulled into a service station shut my truck off let it sit for about 1min the refired it up SES light went out and i had all 4 gears back again tho it delayed slightly before shifting.
Now what ? where do i go from here ? fluids good n full should i replace filter ?
I tried twice to have truck scanned dosn't seem that anybodys reader will link with my truck. . .
I'm guessing the fact that it only dose after i have on the throttle hard that it's prolly tossing the code
DTC 68 - Transmission Component Slipping
but with out being able to link with it i can't be certain but it sure make sense with how and when it goes into limp mode. . .
Trans filter ? as when i did the fluid change they sent me the wrong filter so i didn't change it could this be biting me in the tail feathers now 4-6K miles later ? . . . trans fluid was orange when i changed it its redish pink now . . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #10 of 19 (permalink) Old 12-19-2009, 06:36 AM
Pink means there is water in it. a friend had a simalar problem found out the wiring harness in the transmission needed to be updated.they updated mine to when i had mine rebuilt 2 years ago.Maybe you should check it out.You know come to think of it i had another 4l80e that had the same problem you are it was a vehicle speed sensor.
Larry6.5dually is offline
The Following User Says Thank You to Larry6.5dually For this addition to TDG:
M123KT-450 (12-19-2009)
4L80E Shift problem rspasoje GM Transmissions 2 07-22-2009 04:33 PM
Cummins to 4L80E richarr9 Diesel Conversion 5 02-04-2009 10:13 PM
93, 4L80E no overdrive whitelightning GM Transmissions 1 02-03-2009 11:30 PM
4l80e & transfer case duramaxin14 Whats Been Sold 4 03-18-2008 12:08 PM
4L80E tranny dieseldummy 6.5L Diesel Engine 6 06-04-2005 02:40 AM
