front drive shaft - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dusty, this thread has received 1 replies and been viewed 1165 times.
post #1 of 2 (permalink) Old 06-20-2010, 04:41 AM Thread Starter
front drive shaft
hey early 1999 4x4 2500hd the slip joint on front shaft is seized what is the best way to break it loose thanks
2003 silverado 2500hd. 4x4 crewcab lb7 6.6 duramax
dusty is offline
post #2 of 2 (permalink) Old 06-25-2010, 04:42 AM
Press or a winch and a big pry to get it loose from the yoke. Use a bar through the yoke to put the pressure on it. I have chained one to a utility pole and towed it apart.
81 Isuzu /C223na, 5spd
keydl is offline
Front Drive Shaft BillsFan 1994-2003 7.3L Power Stroke 1 06-29-2009 01:34 PM
Front Drive Axle Inner Shaft and Inner Shaft Housing Replacement (8.25 S4WD and 9.25 ripmf666 GM Spec Info 0 12-28-2008 11:10 AM
Front drive shaft Pleace 69 1994-2003 7.3L Power Stroke 8 12-27-2008 06:46 AM
sway bar, front drive shaft drgriff Supporting Vendors Forum 1 02-25-2008 12:53 AM
Front Drive Shaft. Got Diesel General Ford Truck and Excursion 5 02-14-2007 03:41 AM
