is it worth it - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01quadcab, this thread has received 8 replies and been viewed 1441 times.
post #1 of 9 (permalink) Old 03-07-2011, 04:10 AM Thread Starter
is it worth it
Kicking around the idea of taking the father in laws 94 3500 2wd and converting it to a 4wd. but curious if it's worth it or where the best place is to get all the parts. I have access to a dana 60 ford to put in it.
01quadcab is offline
post #2 of 9 (permalink) Old 03-07-2011, 07:19 PM
Pardue the Traveler
New 0mega's Avatar
Converting a 2wd is more work than converting a 4x4 truck, you need a 4wd trans and transfercase and you need to clock the tranfercase down if you use a gm transfercase. You need you need both drive shafts, cause the 2wd uses a different rear drive shaft than a 4wd and of coarse there is no front one. There is something about the front crossmember too but I can't remember what it is.
Singles Club member #250
New 0mega is offline
post #3 of 9 (permalink) Old 03-08-2011, 04:52 AM Thread Starter
well I have a 12v a 47rh and a 241 dhd to put in whatever I build. just have access to a 94 for a decent price I think
post #4 of 9 (permalink) Old 03-08-2011, 06:03 AM
Pardue the Traveler
New 0mega's Avatar
You would need a ford transfercase cause. the dodge has the front drive shaft on the right hand side not the left.
post #5 of 9 (permalink) Old 03-08-2011, 02:46 PM Thread Starter
no the 94 and up dodges are drivers drop.
post #6 of 9 (permalink) Old 03-09-2011, 07:39 PM
Pardue the Traveler
New 0mega's Avatar
It could work, but it would take time to get the engine, transmission, transfercase, front axel mounted and then get the truck running. but if you got the time and money go for it.
post #7 of 9 (permalink) Old 03-10-2011, 04:51 AM Thread Starter
well, I am deciding between this and a 92-97 f350 cummins conversion. I want a non ca smog diesel and crew cab also want power windows and locks. so not a lot to work with and the wife doesn't want anything super old. I was thinking late 60's suburban but she said no.
post #8 of 9 (permalink) Old 03-11-2011, 02:26 AM
Pardue the Traveler
New 0mega's Avatar
That's another option, there have been plenty of Fummins done. If had the time and money I would love to swap a cummins in to a 4X4 '96-'00 3500 Chev/GM or a Duramax swap in to the same truck.
post #9 of 9 (permalink) Old 03-11-2011, 04:22 AM Thread Starter
well the wife's dad has a 94 I think I can get it for a decent price or nothing it all depends on the day really. I want reliable mechanical injection this is why i am going 12v. I figure a 600+hp daily driver would do the trick.
What`s a 5.9 worth? banyon 5.9L Cummins (1998.5-2002) 7 03-06-2009 02:47 AM
What is it worth? dieslpower97 1994-2003 7.3L Power Stroke 5 03-02-2009 11:52 PM
Worth SOOTBANDIT 5.9L Cummins 12 Valve (1994-1998.5) 4 02-10-2009 10:17 PM
is it worth it DBogo 5.9L Cummins 12 Valve (1994-1998.5) 5 12-21-2007 04:36 AM
how much are they worth? BigWhiteSicksO General Ford Truck and Excursion 1 03-02-2007 05:44 AM
