Rear drums - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hillbilli, this thread has received 3 replies and been viewed 1453 times.
post #1 of 4 (permalink) Old 05-26-2011, 03:55 PM Thread Starter
Combat Trucker
hillbilli's Avatar
Rear drums
The parking brake is out on my truck, has been since i bought it. Ive been attempting to pull the rear drums but havnt had any luck. Tried the adjuster and beat the drum until i was deaf. One of the guys i work with said i might have to pull the axle to get the drum off. Is this necessary or is it possible the drum is just rusted around the axle and studs and is stuck?
07 Ram 2500 5.9 Megacab
96 k2500 Extcab 6.5TD vin F NV4500 3.73 245k miles
07 Hemi Durango
03 Ram 2500 (Gone but not forgotten)
hillbilli is offline
post #2 of 4 (permalink) Old 05-26-2011, 05:40 PM
BUCK2's Avatar
nope pull the axle and buy all the outer seals to replace with new ones. It is easy to do if you just follow everything just like you took it apart. I jacked the side I was working on really high pulled the axle and cught some of the fluid. Did the brakes and put it all back to gether and repeated teh sames steps on the other side. I barely lost any fluid.
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
The Following User Says Thank You to BUCK2 For this addition to TDG:
hillbilli (05-31-2011)
post #3 of 4 (permalink) Old 05-29-2011, 10:36 PM
What I do is take an air hammer or a big punch and hammer and put penetrating oil threw the stud holes, turn the rim, sand the end of the axle and have at it.
Works every time for me!
When you put it back on, clean the flange, and drum. Put a little never size on the axle flange.
Johnp3 is offline
post #4 of 4 (permalink) Old 05-31-2011, 09:49 PM Thread Starter
Combat Trucker
hillbilli's Avatar
Got ahold of a mechanic and apparently the axle has to be pulled on trucks with the 6.5td and 454. So its on my to do list if it ever stops raining up here.
07 Hemi Durango
rear drums PissPoor General Dodge Discussion 2 08-09-2009 03:22 AM
rear drums on 98 dually PissPoor 5.9L Cummins 12 Valve (1994-1998.5) 3 08-09-2009 03:13 AM
Brake drums offroadvw General Dodge Discussion 2 07-15-2009 01:32 AM
Brake Drums PhilipR 5.9L Cummins 12 Valve (1994-1998.5) 5 03-28-2008 11:23 AM
greazy drums ISB 5.9L Cummins (1998.5-2002) 5 09-28-2007 04:58 PM
