2005 Trailblazer Ext. Code P0014 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeltburn, this thread has received 5 replies and been viewed 6711 times.
post #1 of 6 (permalink) Old 05-31-2012, 04:17 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Guys just thought I would pass this along, Had code P0014 pop up tonight. It reference timing bank advanced or something another. Any how to fix I replaced the CPAS Cam Position Actuator Sensor. And did an oil change. Seems the screens in the sensor clog and do not read correctly. I thought I would post in case any other members run across this.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #2 of 6 (permalink) Old 06-02-2012, 07:17 AM
Mafia member #105
ripmf666's Avatar
Send a message via AIM to ripmf666 Send a message via Yahoo to ripmf666
I think I posted a tsb report about this before I will look when I'm on the laptop not the iPad.
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live tuned by IdahoRob,MPI twins installed by BigDipper,PPE lift pump, BigDipper 30% injectors, BigDipper Trans Precion ML converter.PPE Twin Cp3's.
Alot Of thanks To Kat & Pat at duramax diesels, Joe & Dan at PPE,George aka BigDipper
RIP LBZ 6/1/[email protected]:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
http://www.dieselbuilder.com/Media/P...adoBuild_2.pdf
ripmf666 is offline
post #3 of 6 (permalink) Old 06-02-2012, 01:59 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Is this a common thing Henry? I did a few web searches and found several reports that the CPAS can cause this. I did an oil change and replaced the sensor. (note you have to take the power steering pump loose and it does have 3 bolts in it.) Some things I read were that guys just cleaned the sensor and put in back in others had to replace it.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #4 of 6 (permalink) Old 07-08-2012, 03:35 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
So far so good. Tomorrow the Trailblazer is getting new spark plugs... ( Yeah I said Spark plugs on a compression ignition forum) and a new power steering pump. Hopefully this goes smoothly.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 6 (permalink) Old 07-08-2012, 08:42 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
All done well expect for a new tensor pull and prolly a new belt. Have to get by the GM dealer tomorrow.
Sent from my IPhone 4s An AT&T not so 4G phone via Tapatalk.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 6 (permalink) Old 07-09-2012, 02:55 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
I picked up a Gates tensor pully and belt and it is fixed.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
Trailblazer HVAC blower neeltburn General GM Truck Forum 1 09-14-2010 01:03 AM
Trailblazer dash question neeltburn The Parking Lot 1 04-27-2010 04:20 AM
2005 Trailblazer CEL neeltburn General GM Truck Forum 5 08-13-2009 02:49 AM
Trailblazer AC controls? neeltburn General GM Truck Forum 4 05-07-2009 12:51 AM
water pump in 2003 trailblazer 73racing General Gas Vehicle 1 01-20-2009 02:48 AM
