Anyone running Schaeffer 167 with a G80 differential? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by steved, this thread has received 8 replies and been viewed 3326 times.
post #1 of 9 (permalink) Old 07-11-2012, 01:22 AM Thread Starter
Send a message via Yahoo to steved
I have a 2012 2500HD with a G80 in a 10.5AAM, want to dump the OE fill early to flush the break in junk out and have fresh fluid for towing. I have three gallons of 75w140 Schaeffer 167 on hand, and would obviously like to use it up.
So has anyone ran their 167 (Moly Full Synthetic Gear Lube, SAE 75W-140) with a G80? My concern is chatter, as it didn't play well with the TracRite LSD in my Dodge 11.5AAM and chattered until I added LSD modifier. GM specifically says NO LSD ADDITIVE.
Thoughts?
SOLD - 2004.5 2500 Ram, 600CTD, NV5600, 4.10s, FASS'd, Dynatrac Free-Spin Kit, Gulf Coast 0-1 bypass, Intake and Exhaust.
New - 2012 Chevrolet Silverado 2500HD, 6.0L, 6spd auto, 4wd, 3.73s..
steved is offline
post #2 of 9 (permalink) Old 07-11-2012, 05:22 PM
Pardue the Traveler
New 0mega's Avatar
well, The axle is a 11.5AMM 14bolt not the 10.5AMM 14bolt. The G80 is different then the TracRite that dodge uses. the fluid should be fine, but as recommended don't use the LSD.
Singles Club member #250
New 0mega is offline
post #3 of 9 (permalink) Old 07-11-2012, 05:30 PM Thread Starter
Umm, no; its a 10.5...its a 6.0L truck.
steved is offline
post #4 of 9 (permalink) Old 07-12-2012, 05:15 AM
Pardue the Traveler
New 0mega's Avatar
Either way the fluid should work
post #5 of 9 (permalink) Old 07-12-2012, 09:42 AM Thread Starter
Its a 10.5. No question about it...its the typical old school AAM GM has used since the 70s. Unless there are two versions of the 11.5...
steved is offline
post #6 of 9 (permalink) Old 07-12-2012, 04:32 PM
Pardue the Traveler
New 0mega's Avatar
the gm version looks different then the dodge 11.5 14bolt
post #7 of 9 (permalink) Old 07-17-2012, 01:22 PM Thread Starter
Ummm, 10.5...
steved is offline
post #8 of 9 (permalink) Old 07-17-2012, 09:17 PM
Pardue the Traveler
New 0mega's Avatar
either way as I said it shouldn't matter if you use the fluid, as long as you don't use the LSD additive
post #9 of 9 (permalink) Old 07-17-2012, 10:24 PM Thread Starter
The pictures I posted are of the axle in my truck. I've looked this thing over, it looks just like a modern version of the old Corp 14-bolt, not to mention an 11.5 ring wouldn't even fit into the case. I've also asked this over at Pirate and several members verified this is in fact a 10.5.
I would still like to hear from someone who actually ran Schaeffers...
steved is offline
Anybody running the Locking Rear Differential? Jeremiah Duramax 07.5-2010 (LMM) 11 03-25-2010 05:40 PM
Schaeffer Oil SMN Medium and Heavy Duty 26 01-10-2010 07:35 AM
Schaeffer oil Tornsteel 1994-2003 7.3L Power Stroke 14 10-23-2006 12:32 AM
Schaeffer oil wastedwagesracing Supporting Vendors Forum 4 06-14-2006 05:40 PM
