Considering a 91 Chevy build - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 2 replies and been viewed 1210 times.
post #1 of 3 (permalink) Old 03-22-2014, 04:08 PM Thread Starter
I found a hell of a deal on a 91 Chevy that is under construction. The current owner has already done a lot of chassis work and the tear down. The front has three inch drop spindles, nicely painted frame, and big new chrome rims with new tires on all four corners. It is not 100% complete but there is enough there to make it worth it. It is a truck in a box. But I think it would be a great build. I have a 350 sitting on a stand in my garage begging for a HP build. This would be my first ever GM build so I am not sure where to look for the parts I need. I know about Summit, LMC, and so on. But I was hoping some GM guys could point out a few other sources for parts. Also, is there anything about this body style a first time GM builder should know? I need to do some math before committing to this purchase.
post #2 of 3 (permalink) Old 03-23-2014, 03:33 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
As far as I know that truck has tons of parts and options available to anyone looking to upgrade it, the 350 is almost limitless as to what you can do with it because the aftermarket is huge for SBC engines, one thing I have learned lately is if you want HP, don't skimp on the heads or cam, heads that flow (like some AFR heads) can gain you something like 100hp over stock by just bolting them on!
You need to also consider with that if you want to go EFI, TBI, or Carburated, I guess it all depends what your emissions standards are where you live as well, that may play a factor in your choices
Just from aesthetics stand point I would upgrade the front end to a 95-96 one, they just look better
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 3 (permalink) Old 03-23-2014, 06:55 PM Thread Starter
I rrally want to go with an after market EFI. But this wil be a budget biuld so a carb is what I am going to use. I would like to upgrade the front clip, but the one with the truck is complete and in good shape. Inerior parts is what the truck is lacking most.
7.3 Build Up southern-stroke 1994-2003 7.3L Power Stroke 3 03-08-2010 02:58 AM
Anyone here ever build an AR-15? jeffro22 The Parking Lot 27 02-14-2010 09:05 PM
04 Build later 5.9L Cummins (2003-2007.5) 3 06-22-2009 05:50 PM
I need help finding a build thread on 67-71 chevy 12 valve convertion DodgeThis Diesel Conversion 1 01-22-2009 07:58 PM
how to build covey88 5.9L Cummins 12 Valve (1994-1998.5) 13 01-04-2008 03:10 AM
