tranny for 76 C65 with 427 engine - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by thundersnake, this thread has received 2 replies and been viewed 1411 times.
post #1 of 3 (permalink) Old 08-21-2014, 03:57 PM Thread Starter
Does anyone know what trannys will fit a 76 C65 chevy truck with a 427 engine? It has a New Process 7590 5 sp which seems to be scarce along with parts to rebuild it. We have found several 5 spds but they are hooked up to 366s and seem to be different.
Any thoughts?
Wayne
thundersnake is offline
post #2 of 3 (permalink) Old 08-22-2014, 07:17 PM
Been quite a few years since i delt with the medium gasser's, as i recalled the 427 and 366 shared the same block.. Either way i would believe what worked behind one, would the other also.. I have seen a 366 in a 1ton chevy, early 80's model, and also a 427 in a early 80's chevy one ton.. Both were hooked to the 465 4spd tranny that gm used in it's pickups..
navistar45 is offline
post #3 of 3 (permalink) Old 08-22-2014, 09:03 PM Thread Starter
Thanks for the reply.
We have found several 5 spds that probably would bolt up.The issue here for us is that our bell housing is quite shallow compared to the ones we have found hooked up to the 366s and we are concerned that the input shaft is longer than what we have. If we use a different bell housing it would move the shift lever too far back and might interfere with the hydraulics that we have in this unit. Most of the 5 spds that we have seen have the granny 1st, rather than the regular 1st gear. We're not sure about the tranny mounts.
Wayne
'97 Mack E7 427 intermittent low boost & high EGT FarmerMarc Medium and Heavy Duty 5 04-14-2012 04:26 PM
General Gas GM 427/Ford 429 and Transmission Questions Birken Vogt Medium and Heavy Duty 2 10-20-2011 01:25 PM
Where to find parts for 87 GMC 7000, 427 engine Grasshopper Medium and Heavy Duty 1 05-20-2011 04:54 AM
D-MAX engine and tranny for sale BAP Whats Been Sold 29 11-05-2007 03:51 AM
Interesting, 427 Gas/Roadranger 10 Speed Birken Vogt Medium and Heavy Duty 6 07-25-2006 11:29 PM
