Need help with a TBI chevy truck trans. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by KarTek, this thread has received 3 replies and been viewed 787 times.
post #1 of 4 (permalink) Old 08-03-2007, 04:11 PM Thread Starter
TDG Member Since 2004?
KarTek's Avatar
Guys,
I have a '90 Chevy pickup with a 350TBI. I had a 4l60E in there until last weekend when I swapped it back to the original TH400. I have all the connections back in place except for the vacuum modulator. I can't seem to remember which port it connects to on the TBI unit. Any help would be appreciated - especially it a picture is involved!
Thanks!
-Evan
2000 Ford F250, Merillion, 6sp, AIC, DPTuner, BB turbo, Adreneline pump, modified IDM.
1998 Mercedes E300, Custom injector nozzles, soon to have Eaton M90 supercharger, 7.5mm pump elements, Holset HX40 turbo and a full custom intake and exhaust system = 400HP from 3.0l
KarTek is offline
post #2 of 4 (permalink) Old 08-04-2007, 02:33 AM
It goes to one that has vacuum at idle. Including the manifold
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 4 (permalink) Old 08-04-2007, 01:24 PM
Actually, it goes right to the manifold, the steel line is tapered to fit right into the t on the back, right in front of the distributor. Low vacuum=late shift.
The workhorse: 86 F250 6.9 4 speed 4wd 4.10 gears, electric fuel pump
The other workhorse: 92 F350 2wd crew cab, 92 6BT Cummins, NV4500 and GV overdrive unit, 4.10 rear axle
fellro86 is offline
post #4 of 4 (permalink) Old 08-05-2007, 12:34 AM Thread Starter
KarTek's Avatar
OK, thanks. I'll check it out next time I'm working on it.
-Evan
KarTek is offline
Closed Thread
