trailer brake controller on 06 2500HD - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by germantoy, this thread has received 4 replies and been viewed 2444 times.
post #1 of 5 (permalink) Old 08-07-2007, 03:03 AM Thread Starter
anyone know the process or have a wiring diagram? recomend a controller?
germantoy is offline
post #2 of 5 (permalink) Old 08-07-2007, 10:55 PM
Get a Tekonsha Prodigy with the optional cable harness and you'll have no need for the wiring diagram. Just plugs into the connector box under the dash. And it works great.
2003 CHEVY LT 2500HD Duramax LB7 ExtCab/SB 4X4
Hypertech PP3, Truxedo Box Cover, Hijacker 5W Hitch
haunruh is offline
post #3 of 5 (permalink) Old 08-08-2007, 11:23 PM
tekonsha is good, your 06 should have come w/a wiriing harness plugs into the fuse panel by yoru feet. if not you can order that harness from tekonsha. Prodigy is good
#23 Singles Club
thejdman04 is offline
post #4 of 5 (permalink) Old 08-10-2007, 05:36 PM Thread Starter
ya that harness is sitting in the glove box, so its prewired but has no controler? as you can tell im new to this. Im used to the standard 4 prong trailer hookups with no provisions for brakes.
oh ya thank you!
post #5 of 5 (permalink) Old 08-16-2007, 01:45 AM
The harness that is in the glove box will plug in by your feet by your left foot. You will also have to pull the cover off the fuse box on the drivers side (by the fire wall) and install a 30amp fuse there. There maybe a red "dummy" plastic fake fuse installed in there now. That will recharge the trailer battery (for electric brakes). The harness that plugs in will then have to be wired into your brake controller. just use but connectors and shrink wrap. I used double sided tape and stuck it under the dash.
#23 Singles Club
Closed Thread
