trouble codes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bikernut, this thread has received 5 replies and been viewed 1126 times.
post #1 of 6 (permalink) Old 08-09-2007, 05:23 PM Thread Starter
tameing the Dually Beast
trouble codes
does any one have a site where we can get the trouble codes and other info without purchasing the whole manual or a subscription to Alldata? I have a 2005 3500 4x4 with a duramax but my buddies have Chevy's from all years so interested back to 1996.:smoke
Born to ride into the wind
2016 GMC Denali 3500 Dually
2003 GMC 3500 4X4 Dually Dump (Red)
2007 KZ [email protected] Toy Hauler (White with stripes)
2015 Harley FLHTCUTG Trike
1995 Harley FLT (2 tone Red)
1992 Chevy S-10 Blazer 4X4 (Maroon)(wife's)
1978 Pontiac Trans Am GTA (Black)
John Deere 316 Tractor (John Deere Green)
1997 New Holland 555E Backhoe/Loader
bikernut is offline
post #2 of 6 (permalink) Old 08-09-2007, 05:46 PM
IIRC you can log into here for free and get what you need.
http://www.alldatadiy.com/index.html
or
i still have access to gm and all data. what do you need?
FLASH is offline
post #3 of 6 (permalink) Old 08-09-2007, 07:45 PM Thread Starter
what I would like is for all the trouble codes for at least my 2005 Chevy 3500 and any other info that goes for this truck as I got hit the other day when I didn't have the code and had to have the dealership tow my truck and replace the fuel filter which I could have done as I carry an extra filter but not knowing what the code was when I put the code scan on it I was at a lost in more ways then just the wallet. I don't see any where to get this info for free from
ALLDATAdiy.com it wants a subscription
I had a code of 1093 and another of 1094, I guess the 1093 means low fuel rail pressure but they didn't say what the 1094 code was as it didn't show up as I cleared them both to get the truck off the highway while pulling my 18,000# trailer and when the check engine light came on again I was at an off ramp and parked it safely on the side of the interstate highway.:smoke
bikernut is offline
post #4 of 6 (permalink) Old 08-09-2007, 08:19 PM
DTC P1094
Circuit Description
The engine control module (ECM) uses the fuel rail pressure (FRP) sensor to determine fuel pressure to the fuel injectors. This is then compared to the calculated target fuel pressure as determined by the ECM. The ECM adjusts the FRP by modulating the duty cycle of the control driver of the fuel pressure regulator. Injector pulse duration is determined by the measured rail pressure and the target injection fuel into each cylinder. If a sensor circuit malfunction is detected, or the commanded fuel injection pump flow is not within the proper range for a given engine load and speed, DTC will be set.
DTC P1093
Circuit Description
The engine control module (ECM) uses the fuel rail pressure (FRP) sensor to determine fuel pressure to the fuel injectors. This is then compared to the calculated target fuel pressure as determined by the ECM. The ECM adjusts the FRP by modulating the duty cycle of the control driver of the fuel pressure regulator. Injector pulse duration is determined by the measured rail pressure and the target injection fuel into each cylinder. If a sensor circuit malfunction is detected, or the commanded fuel injection pump flow is not within the proper range for a given engine load and speed, DTCs will be set.
FLASH is offline
post #5 of 6 (permalink) Old 08-09-2007, 08:25 PM
i'm trying to find a condensed list of codes and they're meanings. it's not easy cuz there's a lot of codes on these newer vehicles.
FLASH is offline
post #6 of 6 (permalink) Old 08-09-2007, 10:40 PM Thread Starter
thanks
bikernut is offline
Closed Thread
