Mounting CB near brake controller?? is this bad - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by germantoy, this thread has received 3 replies and been viewed 776 times.
post #1 of 4 (permalink) Old 09-08-2007, 08:27 PM Thread Starter
i may have to move my brake controller because i installed a cb in the dash pocket under the climate control. The unit is about 6-8 inches from the Prodigy. I just read that RF emiting things should be a foot away atleast?
I dont want this to be detrimental and im leaving for a 1000mile trip tomorrow
germantoy is offline
post #2 of 4 (permalink) Old 09-09-2007, 01:24 PM
fordt
I have heard about these things causing problems, but who knows. Also it may be the CB that gets all wacky instead of the brake controller :shrug:
post #3 of 4 (permalink) Old 09-09-2007, 01:31 PM
bmoeller's Avatar
Don't how either was wired in, but if you hook the CB ground to one of the batteries, that should help.
Keep the coax away from any wiring helps. If the coax poorly shielded, it can pick up interference from the other electrical wiring. Same goes for the speaker lead wire if you used an external speaker. If the ext. ant wiring is near the coax, it will cause a lot of noise, and sometimes squeal at you.
"Obama = Hoax and Chains"
bmoeller is offline
post #4 of 4 (permalink) Old 09-09-2007, 10:02 PM
I agre if eiverthuyng is sheilded and hooked up properly shoudl be ok.
#23 Singles Club
thejdman04 is offline
Closed Thread
