Exaust pros&cons - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by firehillbilly, this thread has received 12 replies and been viewed 1108 times.
Closed Thread
post #1 of 13 (permalink) Old 09-12-2007, 01:55 AM Thread Starter
resident mason
firehillbilly's Avatar
Exaust pros&cons
Is there a huge difference between the egt's with a cat back and a turbo back. also I see a new wrapped downpipe available for the dmax, anybody have one?
06 Sierra 2500 4wd lb. Predator, S&B, MBRP duals-no cat, Quadzilla gauges, Allison Jr., Riderite air bags, PPE Tie rod sleeves, egr plate / finger stick. 02 Chevy 3500 8.1L 4wd dump 9' Fisher mm2, sander. 03 Kubota L4630. 80'S or 90's Komatsu pc50. 89 d250 5.9 which may someday go into something.:
firehillbilly is offline
post #2 of 13 (permalink) Old 09-13-2007, 12:09 AM
there was a study in disel world a few months back between the 2, not much difference in egt's and dyno numbers.
#23 Singles Club
thejdman04 is offline
post #3 of 13 (permalink) Old 09-13-2007, 12:58 AM Thread Starter
resident mason
so for the extra $300 is it worth it to go to the turbo? also any idea on how many additional ponies you can run through a Allison before failure? I've heard anywhere from as low as none to as mich as 150? I'd like to through in a torque conv. and be safe for 450 rwhp.
post #4 of 13 (permalink) Old 09-13-2007, 01:43 AM
$300 for a front pipe? IIRC, most of the aftermarket exhausts are from the turbo downpipe flange back....thats what they call "turbo back". I don't think any of them have come up with a new downpipe.
I'd say there'd be a big diff between turbo-back and cat-back, as you're eliminating another restriction in the cat converter.
TheBac is offline
post #5 of 13 (permalink) Old 09-13-2007, 02:18 AM
Summit has a 4" d-pipe, I'm getting one as soon as i get the $$. $400 for a 4" system and $500 for 5", both have the 4" d-pipe (stainless only avail. in 4"). I had planned on using header wrap on the d-pipe, It's only $20 worth a try. Most of the other companies out there that advertise "turbo back" actually mean "turbo downpipe back". If you are wondering call each manufacturer and ask them directly, I have only found two that offer larger downpipes. There might be more but I haven't looked that hard, just the big names.
mckey73 is offline
post #6 of 13 (permalink) Old 09-14-2007, 12:40 AM Thread Starter
resident mason
the d-pipe I saw in the Oct. issue of D.P. is from Diamond Eye Performance and is wrapped already, says it'll reduce egt's by 150.
post #7 of 13 (permalink) Old 09-14-2007, 11:34 AM
mckey..good idea on the exhaust wrap.
TheBac is offline
post #8 of 13 (permalink) Old 09-14-2007, 07:38 PM Thread Starter
resident mason
what exactly does wrapping pipes do anyway? I can see where it would stop the transfer of heat to surrounding parts but there's got to be more to it than that.
post #9 of 13 (permalink) Old 09-14-2007, 11:11 PM
Keeps the heat in the pipe, not radiating into the engine bay.
heat = energy.
TheBac is offline
post #10 of 13 (permalink) Old 09-14-2007, 11:49 PM
in diesel world this month, jsut read the article. w/o changing anythign else, the difference between the 2 on their test vehicle a ford , was 200 degrees diff on egt's and 3 ftlbs of torque between the 2 exhaust. Would imagine if you got an apppropriate intake to go w/the exhaust you could see a bit more of a change. ceramic coating si even better then tape but tape is good, keep heat out fo the engine bay, keep the heat in the pipe out of the engine bay.
#23 Singles Club
Closed Thread
