'07 tahoe 6'' lift - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dustindiesel, this thread has received 3 replies and been viewed 897 times.
post #1 of 4 (permalink) Old 09-19-2007, 02:35 PM Thread Starter
SIZE MATTERS
'07 tahoe 6'' lift
im going to put on a 6'' lift and 35's on my g/f tahoe and the dealorship is giving her ***** about it saying that all of the warrenty is void. is there any truth to this or is it only void if the mod effects the problem directly??
its only 35's so its not like the 5.3 and the trans is going to have a prob but i wanna know its covered if something goes wrong that needs to be fixed..maybe i jus need to find a mod friendly dealor??:
2003 psd 6.0
red crewcab, 16" suspension lift, 395 85 20 michelin xml tires, 20'' black rockstar rims, zoodad mod,gutted cat & no muffler, train horns, ccv mod, high idle mod, egr delete,recon smoked cablights,code 670 alarm w/ remote start
1979 ford full size bronco mud truck, 13'' lift , 44'' tsl's, 351 modified w/lots of goodies, 5.38 w/ spools front and rear, dana 60 rear with 35 spline axles, open header exhaust, msd ignition box w/ 5000rpm redline chip
almost 20k invested(somehow)
http://i79.photobucket.com/albums/j1...withold059.jpg
dustindiesel is offline
post #2 of 4 (permalink) Old 09-19-2007, 02:53 PM
Find a different dealer. If you plan on wheeling get some tie rod sleeves and maybe cognito braces. Kat gave me a super good deal.
mckey73 is offline
post #3 of 4 (permalink) Old 09-19-2007, 04:15 PM Thread Starter
SIZE MATTERS
not planning on off road..she jus like the look.its not gonna b abused at all she drives like a grandma.ill jus have to ck around to find another mod friendly dealer
2003 psd 6.0
post #4 of 4 (permalink) Old 11-30-2007, 12:48 AM
moss-magnuuson act prevents a manufacturer from voiding your warranty, unless they can specifically prove the modifacations you did directly caused the parts to fail.
example, you go to the dealer with a rod hanging out the side of the block.. dealer cant refuse warranty b/c of a lift UNLESS it appears that the engine blew from abuse(mud caked undercarriage etc.)
dont go to a dealer and expect them to warranty broken axle shafts u joints,worn steering parts or diag driveline vibrations(under warranty) with a lift and oversized tiresd/wheels
it is actually at the dealers dicretion to warranty or to deny it... i guess is all depends on the service managers mood, and if the dealerships warranty numbers are to high(when i was a ford tech, the dealership was only allowed to do a certain percentage of warranty vs. non warranty work each month).
best thing to do is get in good with your local service manager. things like telling the owner how pleased you are with the service dept. and taking the service manager to lunch will get you some leverage when it comes time for warranty claims
fl-krawler is offline
Closed Thread
