Switches in cubby hole - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fordt, this thread has received 9 replies and been viewed 1351 times.
post #1 of 10 (permalink) Old 10-11-2007, 02:38 PM Thread Starter
fordt
First off, I am not taking credit for finding these switches, and coming up with the idea. The original thread is HERE.
Got my switches installed, and DAMN these babies look good, you can't tell that they are not factory equipment! The fit is awesome! You have to have a center console truck, that has the cubby hole right above the cupholders. A big THANKS to peekok on DieselPlace for finding these switches, and researching which would fit the best. Took about 2 hours to get everything wired up and the switches installed. I orignally ordered all On/Off unlit switch bodies, but I am reording lit bodies and rockers since at night they can't be seen. I am also ordering one momentary on body for my train horns. I ordered the soft rocker actuator, they are a little more money, but I like them alot better. I will keep all the same color since I think it keeps the factory look. Right now I have them hooked to train horn, air compressor, FASS lift pump, and my speaker amp.
post #2 of 10 (permalink) Old 10-11-2007, 02:43 PM
Banned
Looks sharp Wayne. Where did you get them switches from? Geese clean that thing up I can see all the micro dust in the huge picture you posted...
wastedwagesracing is offline
post #3 of 10 (permalink) Old 10-11-2007, 02:47 PM Thread Starter
fordt
www.waytekwire.com
I can post up a complete list of what is needed. I also ordered 500' of 3/8" loom and 1100' of 1/2" loom CHEAP!
post #4 of 10 (permalink) Old 10-12-2007, 01:23 AM
I love Waytek, they have some pretty good prices, I usually dump a good 5-700 bucks each time I order though...
I've seen those switches, but never tried them, looks very good in there.
What did you use for the backing Wayne?
Eric Merchant
www.Merchant-Automotive.com
Zeeland, MI
1-866-399-7169
ASE/GM Master Certified
AC Delco Independent Repair Center
Authorized Suncoast dealer/installer
State of Michigan Licensed Repair Facility
dmaxalliTech is offline
post #5 of 10 (permalink) Old 10-12-2007, 02:40 AM
diesel idiot
very clean very nice. i may have to steal this idea as well.
2004 Chevy CC/SB LB7 LT3
EFILive, SC Trans w/ 1058 by me, Traction bars and centerlink braces built by me, Custom adjustable stock wastegate, 6 inch custom exhaust, 1792 Lift Pump, Belltech 3" drop shackles, Black H2's w/ Falken 285/60/17s for summer, BFG 315/70/17s for winter, SD sleeves, DiPricol EGT and Boost gauges on the pillar along with an Aeroforce for rail PSI and trans temp, 2 Kicker Comp CVT 10's w/ memphis amp, t-rex full face billet grille,limo tint, .Oh yeah I'm 20 and I built and tuned it myself.
tahoedmax is offline
post #6 of 10 (permalink) Old 10-13-2007, 02:13 AM Thread Starter
fordt
No backing, when you put them into the cubby, they are almost an exact fit, the tabs, push down on the top and bottom of each mounting peice. I used a couple screws on the backside to hold the switch panel in, it's solid. I will post up the order list by part #'s if someone wants to duplicate it.
post #7 of 10 (permalink) Old 10-13-2007, 06:30 AM
diesel idiot
I would like it.
post #8 of 10 (permalink) Old 10-13-2007, 11:47 AM Thread Starter
fordt
www.waytekwire.com > Products > (Category) Switches > Contura Rocker - HERE
There are minimums order quanities, but they are pretty much inline with what you will need.
3 - Removal Tool
7 - Contura Actuator's (many styles/colors/lit or unlit to choose from)
7 - Contura Switch Bodies (many to choose from, depending on how many terminals, and style of modes you want/need)
5 - Middle Mounting panels
2 - End Mounting panels
That's all you will need for the switch panel. If you don't need or want 7 switches you can buy these blanks to put in.
post #9 of 10 (permalink) Old 10-13-2007, 12:07 PM
Send a message via AIM to badfish57 Send a message via MSN to badfish57
pretty clean setup:Thumbup:
badfish57 is offline
post #10 of 10 (permalink) Old 10-13-2007, 04:37 PM
diesel idiot
Thanks Wayne :Thumbup:
Closed Thread
