Lmm, Lbz, Lly, Lb7 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Smokem, this thread has received 3 replies and been viewed 4016 times.
post #1 of 4 (permalink) Old 12-30-2007, 09:55 PM Thread Starter
Lmm, Lbz, Lly, Lb7
LMM, LBZ, LLY, LB7 Where do you find these engine codes at on the trucks? Sorry if it's a stupid question. I gotta go Duramax shopping for another buddy. Any other basic info would be greatly appreciated as well.
Smokem is offline
post #2 of 4 (permalink) Old 12-31-2007, 12:06 AM
Look on the VIN for the 8th digit for engine ID.
1 - LB7 (2001-2004.5)
2 - LLY (2004.5-05)
D - LLY/LBZ [note: The LLY of these years is actually an LBZ with different tuning. So check the build date (IIRC on the drivers door) before you buy. IIRC, the switch was in Jan of 2006.]
6 - LMM
Allison trannys were 5 speeds 2001-2005. 2006-up are 6 speeds with tap shift.
TheBac is offline
post #3 of 4 (permalink) Old 12-31-2007, 11:10 AM Thread Starter
That's the run down I was looking for.
Smokem is offline
post #4 of 4 (permalink) Old 02-05-2010, 12:33 PM
DrHolliday's Avatar
2 - LLY (2004.5-05)
6 - LMM
I know this is an old thread, but just wanted to update this.
The 06 LLY still has a 2 in the 8th digit of the vin. Its still the same hard parts as the 06 LBZ with the D in the vin. They both have 6sp allisons as well.
Chris
2006 Chevy 2500HD LBZ/Allison ECSB 4x4 Greystone metallic
S475, 3" boost tubes, 5" intake, Custom Y-Bridge
Tuning and Transmission by Diesel Addiction . A special thanks to Dustin for all the help.
12.42 @ 106.3 (stock injectors, CP3, and turbo, no drugs!)
7.83 @ 86.2 1/8th
531 RWHP / 940 RWTQ 10/11/08 on Wayne's Dyno in Jville NC
USMC 2002-present
DrHolliday is offline
The Following User Says Thank You to DrHolliday For this addition to TDG:
Rcannon (02-05-2010)
