Please help, 4wd wont engage - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jrdragdad, this thread has received 5 replies and been viewed 810 times.
post #1 of 6 (permalink) Old 01-03-2008, 12:56 AM Thread Starter
And i get a message on the dic that says service 4wd. I have a 07 classic w lbz could someone give me some leads to check?
thanks
jrdragdad is offline
post #2 of 6 (permalink) Old 01-03-2008, 10:47 AM
Encoder motor. Did the message just pop up on startup, or did the 4wd really not engage?
TheBac is offline
post #3 of 6 (permalink) Old 01-05-2008, 01:46 AM Thread Starter
mostly the latter, at first there was a message but it works, then now it wont engage and appears to time out and the message appears. if i keep trying if i shut the truck down and then retry again it might work.
is it a major problem or something easily fixed?
phil
post #4 of 6 (permalink) Old 01-05-2008, 02:49 AM
I asked if it happened on startup because on the newer GM trucks, the BCM sends out a "wake up" signal to all the different modules at startup. If it doesnt receive a "Hi, how are ya" back within a set amount of time (even if the module is working correctly), then the BCM passes over that module, and it sets a message on the DIC.
If the 4wd is not engaging, then the encoder could be bad. I'd take the truck back to the dealer for warranty.
TheBac is offline
post #5 of 6 (permalink) Old 01-05-2008, 01:55 PM Thread Starter
thanks, i was thinking i was going to have to do that it has 40 k on it is it a expensive fix?
phil
post #6 of 6 (permalink) Old 01-05-2008, 10:19 PM
Check with Merchant Automotive on parts price.
TheBac is offline
