Duramax EGR system - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MB84, this thread has received 14 replies and been viewed 16206 times.
post #1 of 15 (permalink) Old 01-21-2008, 05:19 PM Thread Starter
Duramax EGR system
What is the purpose of people deleting the EGR system on their trucks. Would this benefit me with 4" straight exhaust, afe stage 2, bully dog pmt? my truck is throwing a dtc code refering to the egr circulation flow. The only thing I can think of that would cause this is the straight exhaust. But im not sure.
MB84 is offline
post #2 of 15 (permalink) Old 01-21-2008, 09:38 PM
i have a catback and afe intake with a hypertech and get the same code
CHORIZOSDMAX is offline
post #3 of 15 (permalink) Old 01-22-2008, 12:16 AM
If your truck is throwing a EGR code and you have a 4" turbo back straight exhaust it is probably not registering the propper amount of back pressure. A finger stick should fix your problem. I do not have any experience with the bullydog, but I do not see where it gets rid of this code. What is the exact code?
imported_redneckbuckeye is offline
post #4 of 15 (permalink) Old 01-22-2008, 03:46 AM
Kat
Most people when doing exhaust usually do a EGR blocker plate and finger stick to eliminate the codes.
People that deleting the whole EGR are mainly doing it when they install aftermarket chargers.
Kat is offline
post #5 of 15 (permalink) Old 01-22-2008, 10:30 AM
Guess I got lucky, as so far never had any codes pop up. I do have a turbo back system running together with Superchips running the original air filter. Would that make the difference? :squish
DieselMonk is offline
post #6 of 15 (permalink) Old 01-22-2008, 11:17 AM Thread Starter
Ok. so a finger stick will eliminate the codes. But what does blocking the egr do for performance, or does it? Thanks.
MB84 is offline
post #7 of 15 (permalink) Old 01-22-2008, 11:15 PM
p0103 code Mass or Volume Air Flow Circuit High Input. I have tried both the finger stick as well as the ppe code eliminator but still codes. Code disappears when i install ppe tuner. Turbo back exaust and blocker plate. Blocker plate keeps exaust gas from going through exaust gas recirc valve and into the air intake.
2007 Classic Chev 2500hd crew cab
6" pro-comp lift and torsions tweaked
buck stop baja front bumper
35" procomp xtreme all terrains on **** cepek dc-1's
p.p.e. econo tuner
finger stick and egr blocker plate
n-fab side steps
mbrp turbo back duals
hendrixk69 is offline
post #8 of 15 (permalink) Old 01-23-2008, 03:38 AM
You're not recirculating the soot.
TheBac is offline
post #9 of 15 (permalink) Old 01-23-2008, 12:50 PM Thread Starter
Will blocking the egr with that plate decrease mpg or harm my truck?
MB84 is offline
post #10 of 15 (permalink) Old 01-23-2008, 11:23 PM
MPG differences in either direction will be minute, and it will not harm the truck.
